Old 24-11-2014, 15:46   #16
Nov_24
Bad results, 69% CDA only.
Old 25-11-2014, 19:55   #17
88% decoded audio in this 22 minutes long log.
Old 28-11-2014, 15:43   #18
Nov_28
Some audio heard about ~7 mins after start up and when decoding was possible. Bad results.
Old 29-11-2014, 15:31   #19
Nov_29
A bit better tonight but still unlistenable.
Old 30-11-2014, 15:43   #20
Nov_30
Even better tonight, ~72% CDA.
Old 03-12-2014, 15:33   #21
Dec_03
A result at ~83% CDA. When the signal drops below 55dBuV decoding stops.
Old 09-12-2014, 15:29   #22
Perfect signal this evning. Log 23min CDA 99.99%ok
Old 13-12-2014, 15:32   #23
Dec_13
A result at ~93% CDA for 22 mins.
Old 13-12-2014, 15:42   #24
CDA 97.38%ok very good signal this evning.
Old 15-12-2014, 15:32   #25
Dec_15
An unattended log. Bad results.
Old 20-12-2014, 15:36   #26
Good results with Newstar DR111 set to AM mode and connected to an external active antenna, fed the 11.5 kHz IF from the DR111 out to a PC with DReaM V2.1.1. (or, perhaps un-cool?)
Old 20-12-2014, 16:42   #27
Dec_20
Bad results here...may be except of the last 5 mins.
Old 22-12-2014, 15:36   #28
Dec_22
~45% CDA...
Old 22-12-2014, 15:40   #29
CDA 93.99%ok
Old 23-12-2014, 15:33   #30
Dec_23
A TX break down at ~16H01, the results turned much better after 16H17.
