Old 05-11-2014, 01:49   #61
Linux-DRM
Confirmed, silent here too, heard the ident at the end though.
Cap
Radios: MR 27024, 2 x Tecsun PL-660, Eton G3 & E5, Tecsun PL-365
Antenna: Homebrew Magnetic Loop (3-30MHz)
Software: Dream v2.2 (svn924) on Ubuntu 14.04 LTS
Linux-DRM is offline   Reply With Quote
Old 05-11-2014, 22:12   #62
Her is 55min log from today . Strong signal stringth S9+30db. Good propagation.
Old 05-11-2014, 22:32   #63
Nov_05
Strong signal, there was a period of high SNR, then the signal dropped and some decoding problems occurred, ~99.5% CDA.
Old 06-11-2014, 22:21   #64
Nov_06
At ~18H25 a short TX break down took place and at ~18H43 the signal dropped and disappeared.
Old 06-11-2014, 23:04   #65
Good signal , CDA 98.03%ok But one TX stop..
Old 07-11-2014, 19:18   #66
Today only CDA 91.14% ok
Old 07-11-2014, 19:38   #67
Nov_07
There was a period of ~12 mins with bad results when the signal turned very weak, the rest was perfect.
Old 08-11-2014, 18:49   #68
Nov_08
A co-channel QRM, at 18H05 for ~5 mins, killed drm. At ~18H17 the signal dropped, no decoding and finally I stopped the log.
Old 09-11-2014, 19:05   #69
CDA 27 % ok so this band is very bad for DRM .
Old 09-11-2014, 19:17   #70
Nov_09
Here's an unlistenable transmission, although the signal was >60dBuV the SNR was low.
@ Sixten:
Not only because that but also due to the high BR and mode.
Old 10-11-2014, 19:17   #71
9 Nov 2014 : RRI SNR Tiganesti 5940 kHz
2% decode!
18:00-21:00 UTC Planetary K-index 3. Local K-index 4.
Planetary A-index 8. Solar flux 132. Sunspot number: 92.
Old 10-11-2014, 21:25   #72
10 Nov 2014 : RRI SNR Tiganesti 5940 kHz
<1% decode.
18:00-21:00 UTC Planetary K-index 3. Local K-index 3.
Planetary A-index 27. Solar flux 136. Sunspot number: 78.
Old 10-11-2014, 22:27   #73
Mikey
Has anyone here sent in a reception report to RRI? Will copy the link of.this thread to them.
Mikey is offline   Reply With Quote
Old 10-11-2014, 23:19   #74
Nov_10
Two TX break downs after the start up then some minor dropouts.
Old 11-11-2014, 19:01   #75
Nov_11
55 mins at 98.4% CDA.
