Old 04-08-2013, 21:00   #16
No good conditions today. The back lobe did not work at all.
Old 06-08-2013, 07:04   #17
It seems that the transmission site is Issoudun in France
http://www.dxaktuell.de/2012/09/kunf...dio-andernach/
Old 06-08-2013, 08:57   #18
... but further down the site has been changed to Nauen:
"Aktualisierung: Nach Informationen der Bundeswehr wurde für den öffentlichen Test die Sendestation Nauen bei Berlin verwendet."
BTW, yesterday (Monday) 13590 kHz was too weak here to log anything.
Old 06-08-2013, 13:01   #19
Now (1156 UTC) on 15410 kHz with co-channel AM QRM. I believe AIR ended their transmission at 1200.
Here's the log, ended around 1330 UTC:
Old 06-08-2013, 16:31   #20
f1tay
Received at Paris about 12h50 at 14h30 T.U. on 15410 kHz.
f1tay is offline   Reply With Quote
Old 07-08-2013, 07:25   #21
DRM-Belarus
DRM-Belarus's Avatar
Low spread delay. Reception in Minsk on 6th of August.
DRM-Belarus is offline   Reply With Quote
Old 14-09-2013, 23:25   #22
11650 kHz, Radio Andernach
I got this Radio Andernach on 11650 kHz. No decoding.
Old 15-09-2013, 00:11   #23
RafaelColDRM
RafaelColDRM's Avatar
Hi All
Here in Colombia noted with only SNR 9dB, always my Winradio G303i need more
to SNR 12dB to decoding
File Type: jpg 11650_Radio_Andernach_2246_14sep20131.JPG (83.4 KB, 203 views)
Good DX
RafaelColDRM
Bogota D.C - COLOMBIA
http://dxdesdecolombia.blogspot.com/
RafaelColDRM is offline   Reply With Quote
Old 15-09-2013, 10:54   #24
Please remember there won't be any decoding as this is an decrypted transmission.
Sorry ;-)
But very interesting to see where you could receive this transmission and what frequencies they are using!
Old 23-10-2013, 23:28   #25
Received tonight
SNR 10dB
Interference from CRI wide AM on 11660
Old 13-12-2013, 23:14   #26
Ant-SWL
Ant-SWL's Avatar
Strong Signal at beginning today on 6040 KHz....
73, Andy
Ant-SWL is offline   Reply With Quote
Old 17-12-2013, 15:25   #27
Today I found Radio Andernach at 1130 UTC on 15430 kHz with a good signal, but it was not rated as good with the DR111 for some reason. I logged with Dream and the FRG-7700 at the same time and got much better results. Unfortunately the PC I logged with decided to stop working due to a silly change I made, so no log from that one.
Old 18-12-2013, 14:29   #28
Today they were on 9410 kHz with AM co-channel interference. At first the Label read "No Service", but on the second channel there was "Radio Andernach". There was a short interruption at 1159 UTC and the co-channel QRM in AM could be heard clearly.
Old 19-12-2013, 14:41   #29
Another short log from the encrypted Radio Andernach.
Old 20-12-2013, 14:44   #30
One hour of strong signal and nothing to hear. How can you hack this transmission, so you can listen in on the "Information" they are providing?
