Old 17-04-2018, 14:04   #1
Woofferton
Woofferton's Avatar
Smile BBC DRM 11970 / 13845 for GA in Mallorca 18th April 2018
There will be a special BBC DRM Broadcast for the DRM GA in Mallorca on Wednesday 18th April 2018 on 11970 kHz between 10:00 and 12:00 GMT.
Broadcast Engineer
Woofferton Transmitting Station
UK
http://babcock.media/
Woofferton is offline   Reply With Quote
Old 17-04-2018, 15:03   #2
Although I was rushing around this morning, getting ready to leave the house, I was able to check a few times the special DRM broadcast on 11970 kHz from Babcock, Wooferton, in the first hour of its transmission. It was aimed down across southern Europe, rather than out to the west towards me. So it's no surprise I heard nothing.
I checked at 1000 UTC, and again at 1015, 1030 and 1050.
I was not able even to raise a label on my Morphy-Richards 27024 set (with eight-metre wire aerial). The MER ratio was so low as to show 0 dB each time I looked. However, the 27024 does show the word "Tuning" when it thinks there may be something there, and about two-thirds of the time while I was staring at the screen, it showed that word. That seems to indicate something was there in the nothingness that I was hearing.
I also checked with my (new) XHData set to see if I could actually hear the DRM whooshy sound in AM mode. I couldn't distinguish anything above the white noise of the 31mb. I tried the XHData both with its whip antenna and with the Sony loop antenna (AN-1) that I had next to it.
So, no luck. Oh well. I'll try again tomorrow if I can.
Old 17-04-2018, 16:32   #3
Woofferton
Woofferton's Avatar
The target area is an island off the east Spanish coast so any reception outside Europe would be of interest. Having said that, we had a successful reception report today from further south in Virginia.
There has been a correction to the broadcast tomorrow:
1000-1100 will be on 11970 kHz
1100-1200 will be on 13845 kHz
Broadcast Engineer
UK
Old 17-04-2018, 17:05   #4
DRM Hdn
DRM Hdn's Avatar
BBC DRM 11970kHz for GA in Mallorca 17th April 2018
Here my reception report of the todays special transmission of BBC WS on 11970kHz.
Decoded audio was 84% and an SNR average of 18,67dB.
After 12h GMT the transmission the broadcast continued, it was longer a recurrent BBC audioloop hearable...
For more details see the logfile.(time line is 1h earlyer)
Old 17-04-2018, 18:02   #5
I receive your special transmission from BBC on 11970 Khz, signal was poor to medium on moment, SNR 5 to 14 db, only very short audio, was dificult for my to receive, many fading.
Mister Broadcast Engineer is possible to confirm with eQSL this reception to my Mail address : 14ZK192@GMAIL.COM, I thank you.
http://nsa39.casimages.com/img/2018/...5123272443.jpg
Only this audio I receive :
Voir le Fichier : DRM_BBC_17418_11970_10H07.mp3
Old 17-04-2018, 20:11   #6
Various European SDRs and Naples, FL
Thanks for putting this on and for adjusting the schedule.
I tried via various SDRs in Western Europe. Best via ones in Spain and Portugal,
but even there only about 50% copy. I could get the initial Journaline screen but the various items did not load.
Absolutely no signal in Naples, FL, USA.
Old 17-04-2018, 22:38   #7
Well ... one can always try tomorrow, I suppose.
Old 17-04-2018, 23:38   #8
Some signal reached as far as New Zealand, but a huge AM signal on 11965 kHz (KTWR I think) didn't help. 0% decoding.
Old 18-04-2018, 13:36   #9
This morning, Weds 18 April 2018, I actually got the label of the BBC World Service on 11970 kHz. (I took a picture of it! ) The label was there every time I checked through the first hour (1000-1100 UTC). The MER, however, was very low, and never more than 0 dB when I checked, so there was no audio here.
The second frequency (13845 kHz in the second hour, 1100-1200 UTC) was weaker still, and there was no label, nor even the indication that the Morphy-Richards set was "Tuning."
Downtown St. John's, Newfoundland, MR27024 set with eight-metre wire aerial.
Old 18-04-2018, 13:44   #10
Very weak signal on 11970 kHz here in New Zealand today. No sign of any signal on 13845 kHz. I didn't bother taking any logs.
Old 18-04-2018, 14:03   #11
Very difficult to receive BBC WS of 11970 Khz no audio only screen :
http://nsa39.casimages.com/img/2018/...5444261148.jpg
Old 18-04-2018, 14:11   #12
Very poor signal of 13845 Khz is extremly reception to my home no audio :
http://nsa39.casimages.com/img/2018/...0236959406.jpg
Old 18-04-2018, 14:41   #13
Naples, FL Reception
11970 got the ID screen, the text message box, and a snippet of audio at 1056.
13845 I got the ID screen only briefly at 1115.
Hans Johnson
Naples, FL
Gospell GR-216
Wellbrook ALA-1530
Old 18-04-2018, 14:42   #14
Europe SDRs
Same as yesterday, 50% copy and no Journaline details.
Old 18-04-2018, 15:08   #15
DRM Hdn
DRM Hdn's Avatar
Here my reception report of the todays special transmission of BBC WS on 11970kHz and 13845kHz:
11970kHz: Decoded audio was round 92% with an SNR average of 21,31dB.
(logfile 1h earlyer)
13845kHz: i saw only the "start spike" in the sdr spectrum and then was no signal to detected.
