Old 17-04-2018, 12:54   #1
alokesh
Spaceline DRM Txn for DRM GA - 18th April 2018
Spaceline DRM Transmission - 18th April 2018
Special DRM transmission tomorrow 18th April from Spaceline during DRM GA at 1200-1400 UTC on 11600 kHz from Kostinbrod, Bulgaria with antenna directed at 260 degrees. The content will be from Mighty KBC.
Reception reports to : reception@spaceline.bg
Alokesh Gupta, VU3BSE
New Delhi, India.
Old 17-04-2018, 21:41   #2
Awesome. I wish this special broadcast would become a staple for KBC and aimed toward Europe with sufficient power to reach North America. Naturally, use robust digital consisting of 16 QAM modulation, xHE-AAC, and parametric stereo.
Old 18-04-2018, 11:35   #3
Nothing heard here on 11970, but according to this article on the Radioworld site, the second hour of the Babcock transmission is on 13845.0 kHz, and I'm getting a trace of the signal, though not enough yet to get a decode from it. I'm probably a bit too close or in the wrong direction for it, but I'll keep trying.
https://www.radioworld.com/news-and-...neral-assembly
Modified NRD-525G with
Radiokit DRM Decoder Board,
SDRplay RSP-1A,
Airspy HF+ Discovery
SDR Console v3
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
https://www.ndblist.info
Old 18-04-2018, 12:32   #4
Very good reception from Spaceline KBC of 11600 Khz in Northeast France SNR 19 to 20,8 db juste in French from KBC " Salut les copains ....." thank KBC is nice, merci Eric.
Old 18-04-2018, 12:38   #5
It's 1220 UTC right now, Weds 18 April, and I've been tuned to 11600 kHz since the 1200 hour. But there is no sign whatever of a signal getting through to here.
Downtown St. John's, Newfoundland; Morphy-Richards 27024 with eight-metre wire antenna.
Old 18-04-2018, 12:45   #6
No sign of any signal here in New Zealand.
Old 18-04-2018, 12:50   #7
Sreen copy /
http://nsa39.casimages.com/img/2018/...4108280636.jpg
Old 18-04-2018, 12:57   #8
Forget :
http://nsa39.casimages.com/img/2018/...4828460726.jpg
Old 18-04-2018, 13:34   #9
Nada in Naples, FL
Nothing here.
Old 18-04-2018, 13:36   #10
SDRs in Europe
Partial copy on a number of them, maybe 30%.
The only thing that I would add to Marcel's excellent report is that the audio
bandwidth was 15.5 kHz.
Old 18-04-2018, 13:58   #11
DRM Hdn
DRM Hdn's Avatar
Wow, what a awesome transmission was that! That was one of the best i heard since years over the DRM standard. Thanks very much! Such broadcasts should continue, absolutely!
Decoded audio from 12:56 to 13:15 UTC was round 91% and an SNR average of 20,17dB.
(Timeline in the log 1h earlyer)
Old 18-04-2018, 14:33   #12
Sadly no such luck here, the panel was displaying okay, and I had occasional snatches, but the last green light just refused to stay on. I must have been just a bit too far north of the main beam. I usually kisten to KBC, so it would have been nice to hear Uncle Eric in DRM for a change.
SDRplay RSP-1A,
SDR Console v3
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
Old 18-04-2018, 19:49   #13
Audio extract from KBC :
Voir le Fichier : DRM_SpaceLine_KBC_18418_11600.mp3
Old 18-04-2018, 19:59   #14
Originally Posted by MARCEL
Merci, Marcel ...
