Old 15-07-2012, 20:05   #76
Strong signal in Switzerland but horrible audio, sometimes with severe ground loop hum. Not even "near short wave quality" audio...
Anyway, the decoding was very good. Listening on the DR111, therefore no log tonight.
Old 18-07-2012, 07:15   #77
Nothing wrong with the reception, but time is ripe for a mode change!
Old 22-07-2012, 09:17   #78
Again, nothing wrong with the reception, but time is ripe for a mode change!
Old 25-07-2012, 20:55   #79
Another perfect log from Nigeria with "almost understandable audio quality".
The SNR on the DR111 was 20-21 dB during the time I looked.
Due to some problems with the audio, some of it was even less "almost understandable".
Old 02-08-2012, 21:25   #80
Despite Kp:5, the reception of this ill-sounding station was virtually perfect. The Doppler looks queer, as queer as the audio.
Old 04-08-2012, 05:57   #81
Newstar DR111
Perfect DRM reception, mostly garbled audio - only one female announcer sounds relatively good. The Doppler constantly rises and at the end of the log it reached its maximum. It's a pity that nobody is able to switch to a slightly better DRM configuration.
Old 04-08-2012, 20:33   #82
Newstar DR111
Perfect decoding, 100% CDA for 85 minutes. Even the Doppler behaved this evening.
Old 06-08-2012, 07:36   #83
Newstar DR111
Perfect reception. Seems like the propagation has improved, as the Doppler was below 1 Hz all the time. The audio is sometimes acceptable (well, almost acceptable), sometimes distorted and garbled.
Old 06-08-2012, 20:12   #84
Thumbs down
This transmission is nothing but a big joke.
The government spent a lot of money for the latest equipment,
and the engineers missed their lesson about how to configure a DRM modulator.
Old 06-08-2012, 20:44   #85
Newstar DR111
At least it is a robust mode!!! No errors whatsoever. But the guy down there who answered my e-mails in the beginning doesn't do that any longer...
Anyway, despite the badmouth from PC Media in Taiwan, here is an example of good reception. If you're not in the target area, what do you expect?
This log was taken with the DR111 sitting on a table in the living-room.
Old 07-08-2012, 20:14   #86
Newstar DR111
Amazing... the Doppler went haywire tonight once more, but the decoding was perfect. Max Doppler reached a maximum of 3.35 Hz at 1956 UTC.
(Sorry, last night the W7 compatibility settings for the Plotter were wrong).
Last edited by Digger : 08-08-2012 at 08:25. Reason: Windows 7 and screenshots... the log is HERE
Old 08-08-2012, 19:55   #87
No transmission this evening? (Checked with two receivers, nada)
Old 09-08-2012, 20:24   #88
Newstar DR111
Back on air tonight, unfortunately with the same miserable configuration. But the decoding was perfect: 100% CDA. Only the Doppler looks peculiar, but it does not impair the decoding at all.
Old 10-08-2012, 23:11   #89
Newstar DR111
Same configuration, same Doppler pattern but 100% decoded audio.
Old 12-08-2012, 20:12   #90
Newstar DR111
Same configuration, roughly the same Doppler pattern but 100% decoded audio.
