Old 02-10-2015, 17:27   #886
2 Oct 2015 : BBCWS Woofferton 3955 kHz
2% overall decoded audio, 99% from 05:57 UTC.
03:00-06:00 UTC Planetary K-index: x. Local K-index: 3.
Planetary A-index: 11. Solar flux: 114. SWPC Sunspot number: 73.
200 km MUF: 2.7 MHz @ 05:00, rising to 3.9 MHz @ 06:00 UTC.
Sunrise 06:05 UTC.
Old 03-10-2015, 06:38   #887
3 Oct 2015 : BBCWS Woofferton 3955 kHz
Zero% decoded audio.
03:00-06:00 UTC Planetary K-index: x. Local K-index: 2.
Planetary A-index: 14. Solar flux: 105. SWPC Sunspot number: 58.
200 km MUF: 3.1 MHz @ 05:00, rising to 3.7 MHz @ 06:00 UTC.
Sunrise 06:06 UTC.
Old 03-10-2015, 10:36   #888
Newstar DR111 spook
I "logged" BBC this morning and got 29.4% decoded audio. Don't ask me why the date and the clock went haywire... I started the log just after 0500 UTC.
A-HAAA, the backup Li-battery voltage is 0.63 V instead of 3 V.
Old 04-10-2015, 06:45   #889
4 Oct 2015 : BBCWS Woofferton 3955 kHz
Zero% overall decoded audio.
Planetary A-index: 11. Solar flux: 95. SWPC Sunspot number: 47.
200 km MUF: 3.6 MHz @ 05:00, rising to only 3.7 MHz @ 06:00 UTC.
Sunrise 06:08 UTC.
Old 05-10-2015, 06:20   #890
5 Oct 2015 : BBCWS Woofferton 3955 kHz
2% decoded audio.
Planetary A-index: 20. Solar flux: 88. SWPC Sunspot number: 18.
200 km MUF: 2.6 MHz @ 05:00, rising to only 3.2 MHz @ 06:00 UTC.
Sunrise 06:09 UTC.
Old 05-10-2015, 07:00   #891
Miserable propagation conditions this morning. Only 8.7% decoded audio. With Doppler above 1 Hz there is no audio.
Old 05-10-2015, 11:50   #892
BBC 3955 KHz reception near Atlanta, Georgia, USA
Poor meteorological conditions with thunderstorms fed by hurricane Joaquin have kept my antenna disconnected, and poor propagation conditions have made reception difficult!
The overnight reception from the back of the beam - no audio decoded, about 4 dB max SNR.
Old 21-05-2016, 19:36   #893
Lost Data from 6th October 2015
Sadly the hosting company had a "catastrophic system failure" and lost all the data from this thread from the 6th October 2015 until the 18th May 2016.
Old 22-05-2016, 05:41   #894
21 May 2016 : BBCWS on 3955 kHz from Woofferton
82% overall decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 2+. Local K-index: 3.
06:00-09:00 UTC Planetary K-index: 4+. Local K-index: 4.
Planetary A-index: 6. Solar flux: 102. SWPC Sunspot number: 43.
200 km MUF: 05:00-06:00 UTC, 3.8 MHz min, 4. MHz max.
Sunrise 04:02 UTC.
Old 22-05-2016, 06:14   #895
Mikey
Thanks for clarifying what happened to all of the posts Neil. Re BBC this morning got 100% decode and audio
Old 22-05-2016, 13:07   #896
22 May 2016 : BBCWS on 3955 kHz from Woofferton
100% overall decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 3+. Local K-index: 3.
06:00-09:00 UTC Planetary K-index: 2. Local K-index: 2.
Planetary A-index: 15. Solar flux: 99. SWPC Sunspot number: 17.
200 km MUF: 5.1 MHz @ 05:00, dropping to 4.8 MHz @ 06:00 UTC.
Sunrise 04:01 UTC.
Old 23-05-2016, 06:27   #897
23 May 2016 : BBCWS on 3955 kHz from Woofferton
03:00-06:00 UTC Planetary K-index: 1. Local K-index: 1.
06:00-09:00 UTC Planetary K-index: x. Local K-index: x.
Planetary A-index: 7. Solar flux: 98. SWPC Sunspot number: 15.
200 km MUF: 4.6 MHz @ 05:00, rising to 5.2 MHz @ 06:00 UTC.
Sunrise 04:00 UTC.
Old 26-05-2016, 06:40   #898
The season is over. Less than 3% decoded audio.
Old 30-05-2016, 07:23   #899
28 May 2016 : BBCWS on 3955 kHz from Woofferton
Only 75% overall decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 2+. Local K-index: 2.
06:00-09:00 UTC Planetary K-index: 4. Local K-index: 3.
Planetary A-index: 10. Solar flux: 91. SWPC Sunspot number: 19.
200 km MUF: 4.6 MHz @ 05:00, rising to 4.8 MHz @ 06:00 UTC.
Sunrise 03:54 UTC.
Old 30-05-2016, 07:25   #900
Mikey
Pretty good this morning. Over 99% decoded
