Old 29-10-2017, 22:35   #1
RRI on 5980 kHz from Galbeni
Hi All,
I was just listening to the 2300 GMT broadcast on 5980 kHz, which is in AM, when suddenly at 2320 it switched to what sounded like a DRM signal, which isn't listed as being on at this time.
I switched on the DRM decoder and Dream is showing this as coming from Galbeni TX1.
I'm not sure if this is a switching error, or if someone is just giving it a quick test, but if anyone sees this post before it goes off you might want to check it out.
Modified NRD-525G with Radiokit DRM Decoder Board,
SDRplay RSP-1A, Airspy HF+ Discovery, Dream v2.1.1
Lancashire, UK 53:39.18N 02:10.28W IO83vp
Old 30-10-2017, 23:28   #2
Oct 30th, 2017 log ... The time of my DR111 has been off several minutes, i.e. 5 minutes in this case, for some time. Maybe, I'll remember to set it properly by the next log ... BTW, I stumbled on this frequency by accident as I hadn't seen the original post.
Very good frequency selection with a poor configuration ... RRI, you can do much better than your current configuration suggests.
Old 02-11-2017, 00:39   #3
Nov 1st, 2017 log ...
Old 02-11-2017, 06:48   #4
Cumbredx
RRI 5980 English DRM 2330
Glenn Hauser is reporting on World of Radio that RRI is using DRM here from 2300-0000 in English.
Cumbredx is offline   Reply With Quote
Old 02-11-2017, 23:19   #5
Cumbredx
No joy tonight on Nov 2nd, listened to 2330 but it was just analog.
Old 03-11-2017, 15:13   #6
2 Nov 2017 : RRI on 5980 kHz from Galbeni
Nothing was received here. During B16 there was an one hour English programme on 6015 kHz from 23:00 UTC.
Old 03-11-2017, 18:52   #7
Glenn Hauser's latest log via his DX Listening Digest mailing list gave the following, I will try and check tonight and see if this is still the case:
** ROMANIA. 5980, Nov 2 at 2330, RRI has reverted to AM, after running DRM by mistake for the first four days of B-17 during this English hour, now with classical music. With DRM I was still able to detect the JBA AM carrier from R. Chaski, PerĂº, amid the noise. Now with BFO, I hear a bit of a warble which could be caused by two carriers on slightly different frequencies, but there is no change between 2334 and 2335 when Chaski should be autocutting off. I am afraid the frequencies are too close together, and the warble may have been due to unstable ionospheric propagation from Galbeni (Glenn Hauser, OK, DX LISTENING DIGEST)
Old 03-11-2017, 23:14   #8
Nov 3rd, 2017 log which my DR111 conveniently failed to save AGAIN ... The poor logging process is one of the few problems that I have with the DR111.
The average SNR was quite good, i.e. 6+ dB with a maximum SNR ~ 9+ dB. Overall, the result was very good for my location.
Old 04-11-2017, 23:20   #9
Nov 4th, 2017 log ... nearly as excellent as 6145 kHz a few days ago.
If RRI had used a MSC of 16 QAM, I would have decoded nearly the entire broadcast ...
Old 05-11-2017, 20:24   #10
4 Nov 2017 : RRI on 5980 kHz from Galbeni
There was 99+% decoded audio during the transmission.
21:00-00:00 UTC Planetary K-index: 1+. Local K-index: 2.
00:00-03:00 UTC Planetary K-index: 0+. Local K-index: 0.
Planetary A-index: 5. Solar flux: 73. EISN Sunspot number: 0.
Sunset 16:30 UTC.
Old 05-11-2017, 23:22   #11
Nov 5th, 2017 log ...
Old 09-11-2017, 16:23   #12
The DRM was back on again last night (Wednesday), wonder if they're alternating the days?
Old 11-11-2017, 04:15   #13
If anyone is still up, or up early, you might like to check 6145 kHz as the 0500 GMT broadcast in Romanian is currently going out in DRM, and is putting quite a good signal into this area. The transmitter is Galbeni TX1, and 20.96 kbps Mono.
I was just waiting up for the Russian broadcast at 0530 on 5940 kHz, I wanted to confirm this one is in DRM if audible (just hope I don't nod off before then!) :-D
Old 11-11-2017, 06:37   #14
10 Nov 2017 : RRI on 5980 kHz from Galbeni
There was 96% decoded audio during the transmission.
21:00-00:00 UTC Planetary K-index: 3. Local K-index: 3.
00:00-03:00 UTC Planetary K-index: 3+. Local K-index: 3.
Planetary A-index: 24. Solar flux: 71. EISN Sunspot number: 0.
Sunset 16:21 UTC.
Old 12-11-2017, 20:53   #15
11 Nov 2017 : RRI on 5980 kHz from Galbeni
00:00-03:00 UTC Planetary K-index: 1+. Local K-index: 2.
Planetary A-index: 12. Solar flux: 68. EISN Sunspot number: 0.
Sunset 16:19 UTC.
