Old 23-09-2019, 20:33   #1
TDF DRM Broadcasts 20th to 30th September 2019?
Hi All,
The Bulgarian DX Blog mentions some TDF DRM broadcasts, 'Minitrans' seems to be the Mini Transat Sailing Race:
http://swldxbulgaria.blogspot.com/20...8SWL+DX-ing%29
FRANCE Additional frequencies of TDF in HFCC (For new organization), updated:
0700-0800 on 13770 ISS 100 kW / 170 deg to WeAf Multi WRMI, inactive at present
0900-1000 on 6105 ISS 100 kW / 255 deg to NWAf French MiniTrans DRM Sept.16-20
1500-1600 on 5970 ISS 250 kW / 255 deg to NWAf French MiniTrans AM Sept.16-30
1500-1600 on 6105 ISS 100 kW / 255 deg to NWAf French MiniTrans DRM Sept.16-30
1500-1600 on 13730 ISS 250 kW / 225 deg to NWAf French MiniTrans AM Sept.20-30
1500-1600 on 15300 ISS 250 kW / 225 deg to NWAf French MiniTrans DRM Sept.20-30
Old 03-10-2019, 15:32   #2
Hi All,
According to a post from Dave Kenny on the British DX Club mailing list, the race has now been re-scheduled for the 5th of October
Old 07-10-2019, 15:15   #3
Good signal here at the moment 1500 UTC on 6105 kHz, but no sign (not surprisingly) of the 15300 kHz transmission. Male in French and a female with French accent, but reading weather info in English at the moment.
The broadcast is showing TDF DRMcast and is in the usual 15.62kbps.
Old 07-10-2019, 16:17   #4
DRM Hdn
DRM Hdn's Avatar
Here was an sufficient signal to receive. SNR Max:22.4dB
The spoken weather infos was strong overdriven.
The reference receiving with the Uniwave was unbearable with this overdriven voices.
Old 07-10-2019, 18:59   #5
Max signal in Northeast France 24 db, many audio cut from fading of 6105 Khz no DRM signal of 15300 Khz :
https://nsa40.casimages.com/img/2019...8591567540.jpg
https://nsa40.casimages.com/img/2019...0249173376.jpg
Old 08-10-2019, 00:56   #6
What DRM receivers are they using on the yachts?
According to VOACAP (see attachment) not much of a chance to decode anything at my location, but the sea-going participants should have good 15.3 MHz signal levels along their route.
The corrected plot is shown in message #17.
Old 08-10-2019, 15:23   #7
Very good signal this day SNR 25 to 29 db of 6105 Khz no signal of 15300 and 13730 Khz.
Old 08-10-2019, 15:56   #8
DRM Hdn
DRM Hdn's Avatar
The todays receiving result is similar to yesterday.
Plotted ca. 30min from this transmission with a MAX SNR of:21,6db.
The reference receiver was today the Multyradio with the same unbeared overdrived voices.
Old 09-10-2019, 19:59   #9
This is one audio extract from yesterday October 10.2019 of 6105 Khz then begin is over modulachen ;
Voir le Fichier : vlc-record-2019-10-09-21h22m01s-DRM_TDF_DRMCast_810196105_15H00WAV-.wav
Old 09-10-2019, 20:02   #10
Today no signal of 6105 Khz I wave signal of 15300 Khz very poor SNR maxi. 6,8 db no possible to decoding.
Old 09-10-2019, 22:16   #11
What time 15300 was broadcasting? Probably strong signal here in Brazil.
Francisco Braccini
DRM: Smart Radio for All!
Old 10-10-2019, 08:05   #12
Hello Braccini,
Time was 15H00 UTC.
Marcel
Old 10-10-2019, 21:48   #13
TDF DRMCast 15300 kHz DRM, 10 OCT 19.
Amazing signal in extreme south of Brazil. I know the Brazilian Carlos Accari from TDF DRM tests: https://photos.app.goo.gl/TaSdKcBnn6GmmhSe8
Thanks all 🌍
Morphy Richards: https://youtu.be/W4pAH-iuEBU
Gospell: https://youtu.be/CRPmLythvsc
Uniwave: https://youtu.be/UOXLxA_NmUA
Francisco Braccini
Old 11-10-2019, 16:05   #14
TDF 15300 kHz
This morning's reception, as expected no audio decoding, max SNR about 9 dB.
Last edited by AF4MP : 11-10-2019 at 16:13. Reason: added transmitter site to log plot.
Old 11-10-2019, 17:07   #15
Oct_11 - TDF on 15300 kHz
I got this transmission with a lot of fading. Distorted audio due to overmodulation, 26dB max SNR.
