Old 02-12-2013, 17:58   #16
Dec_02
A faint trace of the signal tonight, no decoding.
Old 04-12-2013, 18:09   #17
Dec_04
After ~ 30 mins the signal dropped down.
Old 05-12-2013, 22:43   #18
Dec_05
99.93% CDA for 57 mins.
Old 06-12-2013, 17:45   #19
LOg 25min . very strong signal in start S9+40db=74dbuv. 1827UTC start strong AM on 5945khz. First test of my koax switch and speaker system for 2 HAM RX and TX , and antenna output to DRM- RX. And separat MONO AMP. HARMAN KARDON .
Old 06-12-2013, 18:47   #20
Dec_06
Perfect results until 18H09 then lots of dropouts.
Old 10-12-2013, 18:08   #21
Lgog 31min. Perfect S9+30db =64dbuV.
Old 11-12-2013, 19:59   #22
Dec_11
A Tx break down and then lots of dropouts.
Old 15-12-2013, 18:18   #23
Not good here today:
Old 23-12-2013, 19:58   #24
Good reception for a change from Tiganesti on 5940 kHz with a max. of 30 dB SNR. From 19 UTC the label changed to Saftica.
Old 04-01-2014, 18:49   #25
Jan_04
Strong signal but suffered by fast fading and QRM by 2 AM TX on +/- 5kHz. Bad results, continuous sound breaks, too boring for listen up.
Old 07-01-2014, 18:09   #26
Jan_07
Very strong signal tonight reached up to ~70dBuV. Excellent results with high SNR.
Old 10-01-2014, 18:10   #27
Jan_10
After 18H37 the results turned bad with continuous dropouts.
Old 15-01-2014, 18:13   #28
Jan_15
Here are the results for today:
1-Bad results at start up with a lot of dropouts,
2-At ~18H19 the TX broke down,
3-At ~18H33 the TX came back with better results.
Old 21-01-2014, 18:20   #29
Jan_21
The log started with a strong signal (around 65dBuV) but the QRM by the AM TX on 5935 kHz almost destroyed the SNR spectrum (see screen shot) although the SNR reached up to 32 dBs. Around 18H30 the signal dropped down and left a faint trace of it over the noise.
Old 24-01-2014, 17:35   #30
Jan_24
Around 18H17 the signal dropped down and left only a faint trace over the noise. I have noticed this scenario in previous posts.
