Old 16-12-2014, 05:47   #151
15 Dec 2014 : RRI SNR Tiganesti 5940 kHz
32% decode.
15:00-18:00 UTC Planetary K-index 3-. Local K-index 2.
18:00-21:00 UTC Planetary K-index 3-. Local K-index 3.
Planetary A-index: 11. Solar flux: 166. SWPC Sunspot number: 175.
Sunset 15:54 UTC.
Old 16-12-2014, 22:30   #152
16 Dec 2014 : RRI SNR Tiganesti 5940 kHz
78% decode.
15:00-18:00 UTC Planetary K-index 2. Local K-index 2.
18:00-21:00 UTC Planetary K-index 2-. Local K-index 2.
Planetary A-index: xx. Solar flux: xxx. SWPC Sunspot number: xxx.
Sunset 15:54 UTC.
Old 17-12-2014, 20:06   #153
17 Dec 2014 : RRI SNR Tiganesti 5940 kHz
70% decode.
15:00-18:00 UTC Planetary K-index 1+. Local K-index 1.
18:00-21:00 UTC Planetary K-index 1-. Local K-index 1.
Planetary A-index: 8. Solar flux: 185. SWPC Sunspot number: 169.
Sunset 15:54 UTC.
Old 18-12-2014, 18:01   #154
Perfect first 32min CDA 81.70%ok
Old 18-12-2014, 18:37   #155
Dec_18
Very weak signal here, no log.
Old 18-12-2014, 19:46   #156
18 Dec 2014 : RRI SNR Tiganesti 5940 kHz
89% decode.
18:00-21:00 UTC Planetary K-index 0+. Local K-index 0.
Planetary A-index: 8. Solar flux: 192. SWPC Sunspot number: 154.
Sunset 15:4 UTC.
Old 19-12-2014, 17:48   #157
Dec_19
Until ~18H24 there were some decoding problems but the results were rather good, then the signal dropped and decoding turned bad.
Old 21-12-2014, 17:59   #158
Perfect this evning CDA 100%ok
Old 21-12-2014, 18:31   #159
Yes, it was perfect tonight.
Old 21-12-2014, 19:55   #160
21 Dec 2014 : RRI SNR Tiganesti 5940 kHz
50% decode.
15:00-18:00 UTC Planetary K-index 2+. Local K-index 2.
18:00-21:00 UTC Planetary K-index 3+. Local K-index 4.
Planetary A-index: 9. Solar flux: 203. SWPC Sunspot number: 120.
Sunset 15:56 UTC.
Old 22-12-2014, 18:10   #161
Dec_22
A result at 99.6% CDA, the signal drop happened this evening at about 18H43.
Old 22-12-2014, 19:23   #162
22 Dec 2014 : RRI SNR Tiganesti 5940 kHz
59% decode.
15:00-18:00 UTC Planetary K-index 2+. Local K-index 3.
Planetary A-index: 14. Solar flux: 206. SWPC Sunspot number: 159.
Sunset 15:56 UTC.
Old 23-12-2014, 18:04   #163
Good signal her this evning . CDA 98.39%ok MAX SNR 30.07db .
Old 23-12-2014, 18:05   #164
Dec_23
The log followed almost the known reception scenario...
Old 23-12-2014, 21:13   #165
I just switched on for a short time but it was good. Max. SNR was 29.99 dB and 100% decoded audio.
For some (not yet understood) reason my system clock has gone haywire. That's why the time in the log is not quite correct. I suspect DPRK...
