Old 04-12-2010, 18:06   #1
17755 kHz TDP/ The Disco Palace from Montsinery
Transmissions for TDP/ The Disco Palace will be moved to Montsinery on 17755 kHz from Mon Dec 6, maybe some tests already today.
If you are able to receive these transmissions please post results and comments here.
Feedback from listeners in the target area is greatly appreciated.
Thanks,
Old 04-12-2010, 21:10   #2
Brendan1
Brendan1's Avatar
Talking 4 Dec log
Here's a short log of the test transmission today: 100% CDA for the twenty minutes I managed to get. The SNR is also very close (within 3dB) of the maximum strength my receiver and antenna will produce, so today's figure is quite acceptable for me.
I did notice some fading to the signal when listening with an analog receiver, however it was not very strong and was no worse when compared to 15755 from Bonaire.
73s
Brendan WA7HL
Bellingham WA
48.763N, 122.513W - CN88rs
Airspy HF+ Discovery + SDR-Console s/w + 60m dipole
Brendan1 is offline   Reply With Quote
Old 05-12-2010, 21:25   #3
Brendan1
Brendan1's Avatar
5 Dec log
Here's todays report. There were some obvious dropouts (2044-45) and the band faded badly for the last 20 minutes. I had 95.41% CDA for the broadcast period.
I did notice what appeared to be some content feed dropouts during the last hour. I heard the audio go briefly dead, but there was no indication that the signal was having problems (no change to the MSC/SDC/FAC etc. lights).
When compared to 15755 using an analog receiver, I did notice that 17755 was between 5 and 10dB lower in signal strength. There appeared to be an equal amount of fading between the frequencies, except for the last 20 minutes as noted.
I observed no adjacent or co-channel interference here either, and that's a good thing.
73s
Brendan WA7HL
Bellingham WA
Old 05-12-2010, 22:48   #4
This afternoon's reception - 66.72% audio. There was a lot of multipath distortion observed on the spectrum input - which somewhat corresponds to the doppler plot. The signal level was high which was also predicted by VOACAP (see 2nd attachment).
34°02' N, 84°24' W
Old 06-12-2010, 22:16   #5
Brendan1
Brendan1's Avatar
6 Dec log
A much better day today: 98.26%. There was a cluster of dropouts beginning at about 2105 and finishing around 2127, which was the major failing today. No transmitter drops, which is always a good thing!
73s
Brendan WA7HL
Bellingham WA
Old 06-12-2010, 22:48   #6
This afternoon's reception - 78.47% audio. Problems seem to be mainly doppler related, as the signal level was high, but maybe some absorption occured too.
The 2nd attachment shows the spectrum plot at 20:40 when the worst of the propagation hit.
File Type: png TDF Montsinery 17755 kHz 6-Dec-2010 REALLY BAD.PNG (18.3 KB, 294 views)
34°02' N, 84°24' W
Old 07-12-2010, 21:19   #7
PP5AZF-Ataliba
TDP 17.755 khz in Brazil
I think the sign of the TDP in the 17,755 khz arrive at its southern Brazil at the start of transmission.
When I was at a frequency of 15,755 kHz happened on the contrary, ie, the signal was better at the end of transmission.
I noticed that after the 21:20 h started an AM interference. See the picture attached.
Acho que o sinal da TDP na em 17.755 khz chega melhor ao sul do Brasil no início da transmissão.
Quando estava na frequencia de 15.755 khz acontecia ao contrário, ou seja, o sinal era melhor no final da transmissão.
Observei que após as 21:20h começou uma interferência AM. Veja na imagem em anexo.
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
www.youtube.com/atalibazf
Old 07-12-2010, 22:09   #8
Brendan1
Brendan1's Avatar
7 Dec log
Another great day here, only a few small dropouts to mar the decode rate, making it 97.95% today.
Since the early closing seems to be the 'normal' time, I'll shorten my log by 2 minutes to compensate. That would actually bring up the decode rate too!
73s
Brendan WA7HL
Bellingham WA
Old 07-12-2010, 22:41   #9
Much better - 90.63% audio.
If not for the early end of the transmission the report would have been a little better.
34°02' N, 84°24' W
Old 08-12-2010, 01:01   #10
Brendan1
Brendan1's Avatar
I re-ran my data and trimmed the last 5 minutes off: this gained me over 2%, to just under 100%. I'm actually going to reset the logger to stop at :55, this should fix that early closing.
73s
Brendan WA7HL
Bellingham WA
Old 08-12-2010, 21:01   #11
Not as good as yesterday - 87.26% audio. There were also some audio breaks at the input of the transmitter.
34°02' N, 84°24' W
Old 08-12-2010, 23:09   #12
Brendan1
Brendan1's Avatar
8 Dec log
Well, it was 99.94% here today, and only 4 small, short dropouts.
73s
Brendan WA7HL
Bellingham WA
Old 09-12-2010, 21:02   #13
This afternoon's reception - 66.24% audio. Besides the propagation, there were also many audio feed breaks (transmitting stereo silence).
34°02' N, 84°24' W
Old 09-12-2010, 22:37   #14
Brendan1
Brendan1's Avatar
9 Dec log
Only some very small dips here, so my CDA was a very respectable 99.97% today.
73s
Brendan WA7HL
Bellingham WA
Old 10-12-2010, 21:07   #15
Brendan1
Brendan1's Avatar
10 Dec log
Two transmitter breaks in the last half hour, and there were more than a few audio dropouts that are not shown in the decode line. The CDA dropped to 97.85% as a result of the outages.
I'm quite sure the dropouts are coming from the content server, and not the transmitter: the MSC light was steady when listening, and propagation was also very good today.
73s
Brendan WA7HL
Bellingham WA
