Old 31-05-2010, 15:01   #1
0711 kHz >>SWR cont.ra from Obereisesheim
Today SWR have started DRM transmissions for >>SWR cont.ra from their site in Obereisesheim.
If you can receive this transmission, please post results here.
Thanks,
Old 31-05-2010, 16:26   #2
SWR in France
Ich receive of 711 Khz at 16H11 UTC only of screnn no audio I think audio later Night is better for this frequency, SNR : 4 to 6,2 db
http://www.pictonale.net/2010/05/31/fxiu01r/
Very nice this New German station.
Old 31-05-2010, 17:40   #3
Simone, could you merge this thread with http://www.drmrx.org/forum/showthread.php?t=2231 or delete mine, please? Thank you! I'll try to receive SWR in the next days.
Old 31-05-2010, 19:14   #4
A weak signal here in Hessen about 160 km North of Obereisesheim, with 17 dB MER just good enough for decoding with daytime conditions, interference getting stronger now as it gets dark.
Old 01-06-2010, 15:07   #5
A few ripples in the graph at the beginning, perfect decoding from 0435 with daytime conditions.
Old 01-06-2010, 20:15   #6
Two hours with almost perfect results just before dark.
Old 01-06-2010, 21:27   #7
Hallo Simone,
Dass ist ja wahnsin, der SNR ist of 16,2 db und kein Ton und 16,7 1 secone Ton und fertig wieder runter dass signal.
Ist komisch gewönlich mit 9 oder 11 db ist Ton und da nicht !!!!
Dass war um 21H10 UTC.
http://www.pictonale.net/2010/06/01/6mq28lm/
Old 02-06-2010, 20:23   #8
Surprisingly reliable reception at daytime continued today, although signal strength and MER are just at the minimum where it should work.
@ Marcel: I think that´s normal, you need about 17 dB to decode this transmission.
Old 07-06-2010, 08:41   #9
DRM-OM
daytime ok, nighttime useless.
many audiodropouts on transmitter side while log is 100% - disruptions in audio-feedline?
Btw: Wanted to do unsupervised 5day-log over long weekend, but after 2days dream 1.7.5 crashed and pc ran at 100% CPU for the remaining three days
Old 07-06-2010, 20:34   #10
Good results again tonight, just before dark, audio feed problem has been fixed.
Old 08-06-2010, 09:43   #11
Some audio tonight from Obereisesheim, the AM station on 711 kHz was very strong after 2303 UTC and killed DRM decoding.
TX distance is wrong in this log.
Old 08-06-2010, 13:45   #12
DRM-OM
Since 13:10 UT transmitter is off air ...
Old 09-06-2010, 09:00   #13
DRM-OM
Same picture as last week:
This time I used Fhg SWR 4.0.40 which obviously is not fully compatible with DRMcalc so I had to do a lot of manual editing ...
Btw: since around an hour or so the transmitter is working again ...
Old 09-06-2010, 12:51   #14
DRM-OM
transmitter off air once again ...
Old 10-06-2010, 14:26   #15
DRM-OM
... and off air all day so far ...
