Old 23-05-2010, 00:39   #1
RafaelColDRM
RafaelColDRM's Avatar
RNE 9630 Khz
Hi all
At moment RNE in spanish on 9630 Khz, good signal; in // with analogue signal on 6020 KHz and 9535 KHz. Presume from Costa Rica
Good DX
RafaelColDRM
Bogota D.C - COLOMBIA
http://dxdesdecolombia.blogspot.com/
RafaelColDRM is offline   Reply With Quote
Old 24-05-2010, 00:14   #2
Hi Rafael, hi all,
good catch, thanks for the post! Visible right now here in Germany but no audio at 14 dB SNR max. and strong QRM.
Very short log attached.
I wonder if they have started before 0000 UTC already.
Old 26-05-2010, 06:15   #3
An unattended log. High Doppler suggests that the signal originates far from here. Unfortunately, not enough decoded audio to get an automated screen-shot.
Old 31-05-2010, 02:22   #4
Brendan1
Brendan1's Avatar
30-31 May log
Well, I managed to get this log started just 5 minutes after hooking up my 'good' antenna outside after moving.
Fairly disrupted during the first hour, but much better after that. Some adjacent channel interference on 9625 at first, but at 0000Z it shifted off for the better.
Nice to have a new one in the same hemisphere!
73s
Brendan WA7HL
Bellingham WA
48.763N, 122.513W - CN88rs
Airspy HF+ Discovery + SDR-Console s/w + 60m dipole
Brendan1 is offline   Reply With Quote
Old 01-06-2010, 02:27   #5
Brendan1
Brendan1's Avatar
Smile 31 may - 1 June log
Today's observations: DRM carrier came up at 2346 UTC, no audio was heard until 0005 UTC. It would appear that from 2346 to 0005 the carrier was 1) either running at reduced levels, gradually increasing to full power, or 2) local sunset in Cariari (2350) played a dramatic role in changing the signal strength over the path to my location.
No audio heard after 0200, although the DRM signal was on the air until 0205 UTC. The Dream waterfall at the time was showing an amazing portrait of the ionosphere, with the DRM waveform illuminating all of the adjacent spectrum. I have a screenshot of the waterfall, but it is too big to upload.
Great audio by the way, not many 'digital' artifacts could be heard. The impulse response was running from less than 4ms to just over 5ms.
73s
Brendan WA7HL
Bellingham WA
Old 02-06-2010, 02:01   #6
Brendan1
Brendan1's Avatar
1-2 June log
Today's notes: Audio started at 2358, ended at 0147. Carrier came up at 2347, and went off-air at 0149. Excellent signal strength while the broadcast was on, any decoding problems were fairly brief.
It would seem as if the Cariari station is somewhat loose about adhering to a schedule.
73s
Brendan WA7HL
Bellingham WA
Old 02-06-2010, 06:01   #7
1 - 2 June
According to an answer from REE yesterday via e-mail that I got read: "We have planned these transmissions from 0 to 2 am UTC" (from Cariari). There was no mention of the direction of the broadcast. I am most certainly outside the target area.
My unattended log was better than my first try, but the Doppler is higher than 1 Hz all the time which results in no decoding at all according to my experience. The Channel Impulse Response is probably wide and poor as well - that's an assumption. The log is a 30 seconds interval Auto-Plot, which didn't manage to shoot any screenshots due to the absence of decoded audio. That means that I have to get up in the middle of the night to see for myself.
Old 03-06-2010, 02:29   #8
Brendan1
Brendan1's Avatar
2-3 June log
Well, if by starting 7 minutes early and ending 10 minutes early they mean 0000-0200, I guess they are "on time."
{IMHO, a radio transmission should be like a good Swiss train: leave at the exact second it's scheduled, not before, not after. Gotta love punctuality!}
Started at 2353 today, and ended at 0150. Audio was up about 3 minutes later.
I think the azimuth previously given for the REE broadcast was 340, which would put me very much in the path, either here or in Arizona. Given the signal quality, I think that's still the case. I didn't get a chance to check the channel impulse response here today, but IIRC yesterday it was <5ms. I'll try to check tomorrow for sure.
Today's results are extremely good all told.
73s
Brendan WA7HL
Bellingham WA
Old 03-06-2010, 07:15   #9
Then I am definitely outside the target area. And sound asleep...
Old 04-06-2010, 02:08   #10
Brendan1
Brendan1's Avatar
3-4 June log
Terje - Since when is a true DRM fan supposed to sleep? Somewhere there is always a transmission to try and log!
I checked the impulse response, and for the most part it was between 4 and 5ms. Towards the end of the broadcast I noticed that band conditions were deteriorating and it was showing a width of at least 7ms from time to time.
Not so good tonight, mostly because of a high "A" index here I think. Condtions weren't very good for most of my logs today.
The broadcast started at 2356 and ended at 0156. They're getting better at their timekeeping...
73s
Brendan WA7HL
Bellingham WA
Old 04-06-2010, 05:32   #11
3 - 4 June
Hi Brendan and all,
Oh, my passionate DRM years are over, thats why I decided to sleep through this transmission In the 1960's I used to hunt MW DX during the winter nights.
Actually, I let Dream run through the night and the log is enclosed. The Doppler is extremely high and the SNR peaked around 0050 UT.
Old 04-06-2010, 17:21   #12
Brendan1
Brendan1's Avatar
Hi Terje and all,
Oh, I understand about sleeping all night, yes indeed! I'm with you, and a decent uninterrupted night's sleep is a wonderful thing. At least with the DRM programs available for our use we can do unattended logging. Pity the poor analog types who are still manually logging in the middle of the night. Having done a lot of night-time listening in the past, I no longer feel the need to actually be awake.
73s
Brendan WA7HL
Bellingham WA
Old 04-06-2010, 20:30   #13
For those of you speaking Spanish, there is a report about DRM from Costa Rica on REE's website:
http://www.rtve.es/mediateca/audios/...a/790400.shtml
Old 05-06-2010, 06:49   #14
4 - 5 June
Looking at the Doppler, it looks better than the previous nights. But like I said, according to my experience, there will be no decoded audio with Doppler values above 1 Hz with my setup. Zzzzzz. . .
Old 06-06-2010, 01:40   #15
Brendan1
Brendan1's Avatar
4-5 June log
Some weakness in the band last night, and the solar indices were not helping at the time!
73s
Brendan WA7HL
Bellingham WA
