Old 09-10-2007, 13:19   #1
Thumbs up 15795 TDF to Moscow
Hi all,.
Very strong signal stringth her also but very slow fading from S9+30db to S8.On my dipole antenna fr 14Mhz .
Log is 70min.
Reciver is Roadstar portable+mixer SA612AN and telescopic antenna . Please look for my Rx on 15480.
Old 09-10-2007, 17:01   #2
F6AJW
Question
Hi All!
Thank you Sixten,
Yes, an early start as Michel Penneroux, Peter Senger and others were visiting Taldom with an Himalaya receiver in hands.
On 10 and 11 October, we will transmit from Issoudun to Moscow 'DRM symposium) and may be up to Beijing (ITS) on 15795 kHz from 0700 to 1500 UTC with 150 kW into a 4/4/0.8 at 55.
Any listener in Moscow or China?
Regards.
Jacques Gruson
F6AJW is offline   Reply With Quote
Old 10-10-2007, 08:49   #3
10 Oct.
Hi Jacques.
Propagation was very very mystery today.
I test her signal from portable reciver and teleskopic antenna , and my TS930 antenna dipole , same problem propagation krazz totaly.
Old 10-10-2007, 11:27   #4
Ager
Ager's Avatar
No logs attached but a printscreen, its a little closer to Moscow than at Sixtens. Great reception in Finland, very good sound quality and stable signal.
Ager is offline   Reply With Quote
Old 10-10-2007, 13:45   #5
This TX shoots way over my QTH - I'm definitely in the skip zone.
Old 10-10-2007, 17:07   #6
F6AJW
Hi All!
From Ager report, I noticed that the code rate is 0.6 instead on 0.5 as we are transmitting RFI Russia in mono. It will be corrected (I hope...) tomorrow.
No news from China!?
Cheers.
Jacques Gruson
Old 11-10-2007, 03:46   #7
Not so good here in SE China.At the start of logging, weak (S5) but usable signal. After dark falls, signal faded out and All India Radio Chinese service blocking the rest of the programme.
After All Indian Radio off the air, some chances of decode,but not last long.
My Rx location: GuangXi Province @ E10636′ N2355′
Old 11-10-2007, 03:49   #8
see the input spectrum.
Old 11-10-2007, 15:04   #9
Ager
Ager's Avatar
Still excellent reception over here, with Jacques having the text data corrected.
Very nice SNR, no dropouts of any kind, simply perfect.
Old 11-10-2007, 17:05   #10
11 Oct
Her is 58min Log. First 25min come from my portable reciver and last 25min from Kenwood TS930S and dipole antenna.
Roadstar give MAX SNR of 23db not more. So it is not transmitter error !!!!!
Old 11-10-2007, 19:24   #11
tradio99
very good, almost perfect reception till 14.UTC here in Latvia, 100 % audio
Vladimir
tradio99 is offline   Reply With Quote
Old 11-10-2007, 19:51   #12
MOBILE RECEPTION
I tried to receive this transmission on the road in northwestern Germany this morning, but obviously I am too close to the TX. The signal is strong enough but too much distorted by backscatter etc., so as good as no audio.
Old 12-10-2007, 03:07   #13
The lower bit-rate gives much stable result and the timing of drop-out coincides with my previous log:so definitely solar related.
Old 15-10-2007, 17:32   #14
F6AJW
Hi All,
DRM transmission to Moscow and Beijing is now over. I would like to thank all those who sent reports to me. I specially appreciated to hear from DRM reception near Hong Kong / China and I got also a report from Japan via Terje. DRM transmission to China is not easy; the usable time slot is quite narrow and it is not easy to find out a clear frequency (QRM from AIR).
I have no idea if our transmission was used during ITS exhibition in Beijing but I got at least report from Zfyoung in ShenZhen / China!
Regards.
Jacques Gruson / TDF
