Old 09-12-2008, 12:14   #1
CT4RK
CT4RK's Avatar
Thumbs up BBC & DW on 3995 kHz from Sines and Skelton
Hi all
This frequency have no changes in the schedule. Only the program change. Sines will be on air from 22:00 to 23:00 UTC, and from 5:00 to 5:59 UTC.
73 from: CT4RK
Carlos
Sines - Portugal
Old 10-12-2008, 04:25   #2
Please use this thread for results from both sites, Sines and Skelton.
Daily schedule for this frequency:
0500- 0700
1600- 2300
Old 10-12-2008, 06:31   #3
Dec. 10
A morning result from Skelton. Weak signal, most of the time below 30 dBuV, so some decoding problems.
Old 10-12-2008, 08:07   #4
I remembered this new service too late, so here is a short log only.
Old 10-12-2008, 16:54   #5
pb1
3995: Between 17-18GMT almost no reception possible on ordinary Morphy Richards 27024 in Amsterdam the Netherlands.
pb1 is offline   Reply With Quote
Old 10-12-2008, 20:17   #6
A few dropouts this morning.
Old 11-12-2008, 17:41   #7
Perfect reception here from 1647 and 110 min on.
Old 11-12-2008, 21:24   #8
A weak signal in the first half hour from Skelton, otherwise quite good results.
Old 12-12-2008, 06:29   #9
Dec. 12
A result during a morning full of thunderstorms.
Old 12-12-2008, 19:13   #10
Remembering the problems with reception from Wertachtal on this band and the tests from Sines at my location this TX location is a real improvement.
Lower SNR here between 18:00 and 20:00 UTC.
Old 12-12-2008, 20:15   #11
Good results this morning, apart from a few dropouts.
Old 15-12-2008, 16:03   #12
Two TX crashes, so 70% CDA only
Old 15-12-2008, 22:14   #13
As on 5875 kHz, no more problems in the last half hour.
Old 16-12-2008, 09:10   #14
pb1
Could not listen to Newshour yesterday via DRM in Amsterdam (switched to analogue). No reception possible on MR27024 after 22 CET.
Why is 1296kHz switched of so soon?
Old 16-12-2008, 20:21   #15
Dec. 16
Here's a 2 1/2 hours result.
