Old 09-12-2008, 12:03   #1
CT4RK
CT4RK's Avatar
Thumbs up BBC & DW on 13810 KHz from Sines
Hi all
This QRG remain the same, and 13810KHz will be on air. from 8:03 and up to 14:00 UTC.
73 from: CT4RK
Carlos
Sines - Portugal
Old 10-12-2008, 12:51   #2
4 hours and 41 minutes of almost perfect reception. The only problem was a weaker signal around 0940 UTC. The other blips in the log was caused by a 450 MHz TX on my work bench.
Old 10-12-2008, 13:17   #3
Good signal here on this QRG (worse on the other frequency). But neither EPG nor Journaline data can be decoded. :-(
Old 12-12-2008, 19:58   #4
Good results except the dropouts due to the MDI problem.
Old 13-12-2008, 14:50   #5
Great results today (apart from the MDI feed problem).
Old 13-12-2008, 21:22   #6
Similar result here as Simone's, but I was not present. so I cannot tell exactly what happened. My log is 3h40 m long.
Old 14-12-2008, 09:29   #7
Thumbs up Dec 14
Perfect! Excellent reception from DW/BBC on this QRG from Sines.
100 % CDA for 1 hour. Time: 09:24 - 10:25 UTC.
The multimedia service is however not available.
Old 14-12-2008, 10:31   #8
Originally Posted by Per
Hi Per,
sorry, seems there is currently a compatibility problem with this service and the journaline decoder in DRMSWR 2.0.38, in the meantime you should be able to get the dataservice using DRMSWR 2.0.34 or Dream.
Old 14-12-2008, 15:21   #9
Pretty good results for the whole transmission.
Old 15-12-2008, 03:05   #10
Just a short log. Only for experimental purposes.
Old 15-12-2008, 13:43   #11
Most of the audio drop-outs happened exactly at the same time as on 9.610 MHz.
The second log was not the usual good old Sines today.
Old 16-12-2008, 11:40   #12
Perfect today.
Old 17-12-2008, 03:48   #13
A few dropouts due to the MDI feed problems, other wise great results.
Old 17-12-2008, 13:31   #14
Lots of audio problems around 1225. The log is almost 4 hours.
Old 20-12-2008, 15:15   #15
A weak signal in the beginning. The very last minutes of the transmission suffered from rapid decay in the propagation.
