Old 19-08-2010, 21:37   #181
Log today 3h31min.
I switch over to dipole for 14Mhz last 60min. for test but signal from dipole was strong but bad propagtion for DRM from this direction . This dipole is for E/W . beam direction.
Old 20-08-2010, 05:58   #182
19th Aug.
Here some problems around 1445 in my unattended log. My laptop decided to cut the log to pieces around 1635, but no problems here at that time.
Old 20-08-2010, 18:21   #183
Today I had no decoding for 15 minutes from 16:30 - 16:45. I noticed that the sound disappeared, but otherwise the log was unattended.
Old 23-08-2010, 07:46   #184
CT4RK
CT4RK's Avatar
Hi Digger and all
We had a technical problem in the transmitter.
73 CT4RK
73 from: CT4RK
Carlos
Sines - Portugal
Receiver TENTEC RX320 modified, R&S HEO10 active antenna, DREAM software...And...No more PLC/BPL QRM...Thanks ANACOM!
Save the Radio Spectrum! Eliminate Broadband over Power Line.
CT4RK is offline   Reply With Quote
Old 23-08-2010, 07:55   #185
CT4RK
CT4RK's Avatar
Hi all
Because maintenance works in the courtain antenna, from today, and for about 1 month this transmittion will be made with a log periodic verticaly polarized antenna. Is expected that the signal strenght lower at last 6dBs.
73 CT4RK
73 from: CT4RK
Carlos
Sines - Portugal
Old 23-08-2010, 20:13   #186
Mostly a weak signal in the first two hours today, some improvement at 1600, later again problems due to propagation, the last hour was prety good again.
Old 24-08-2010, 18:37   #187
Bad propagation and low signal stringth today. Log 3h19min.
Old 24-08-2010, 20:04   #188
stef
stef's Avatar
Very fluctuating signal,signal goes up and down like a roller coaster.
stef is offline   Reply With Quote
Old 24-08-2010, 20:25   #189
Problems here too with this antenna, however the last two hours were prety good.
Old 25-08-2010, 17:51   #190
stef
stef's Avatar
better today but still fluctuating at the end of log
Old 25-08-2010, 18:47   #191
Much better also on this frequency today.
Old 26-08-2010, 18:44   #192
stef
stef's Avatar
the log today is reverse from yesterday fluctuating in the beginning and more stable at the end
Old 27-08-2010, 18:01   #193
stef
stef's Avatar
Nothing today tx off air?
Old 02-09-2010, 18:05   #194
Good reception, but strong AM interference from 15630 kHz and signal fading short before 18:00 UTC. The EPG is a very nice feature.
Old 13-09-2010, 07:14   #195
Again two receivers, one antenna. This time the FRG-7700 and the RF-B60. The decoded audio was roughly the same for both. I don't know whether the two periods of bad decoding was caused by QRM or bad propagation.
