Old 03-05-2005, 20:04   #31
good results this afternoon, see attachment.
Later I also listened in the car, it is the first time I can switch between FM and DRM listening to the same programme in the car great!
73, Simone
Old 03-05-2005, 20:50   #32
Thumbs down
Again bad results.
Old 03-05-2005, 21:17   #33
some dropouts this evening, see attachment
73, Simone
Old 03-05-2005, 21:45   #34
tradio99
@ dk8cb
Thank you, Roland! Last year I tried different levels and periodically changed line and microphone inputs for better reception, unfortunately, specific detail of my location - most of the signals are weak, so last time I experimented with high input level really, in some cases it gives better SNR. OK, I`ll reduce level again and compare the results.
Vladimir
tradio99 is offline   Reply With Quote
Old 04-05-2005, 17:00   #35
quite good results except during a thunderstorm at the beginning, see attachment
73, Simone
Old 04-05-2005, 21:11   #36
df8uo
Location: Karlsruhe (Germany) and Boulogne-Billancourt (France)
attached my result from 19h30 to 21h35. At 21h30 signal dropped down.
73
Daniel
df8uo is offline   Reply With Quote
Old 05-05-2005, 16:05   #37
df8uo
find attached 70 min log from this afternoon. Signal was quite strong (average S9). However SNR quite low.
73
Daniel
Old 05-05-2005, 22:47   #38
PaulT
PaulT's Avatar
report for this evening. Audio not as bad as it looks. Bit of co-channel qrm.
Paul T
PaulT is offline   Reply With Quote
Old 14-05-2005, 21:19   #39
perfect decoding this evening for 5 hours, see attachment
73, Simone
Old 16-05-2005, 17:03   #40
df8uo
BR 13h00-15h00
quite bad result this afternoon at my location.
73, Daniel
Old 16-05-2005, 21:23   #41
quite good until 1900 this evening, see attachment
73, Simone
Old 31-05-2005, 22:16   #42
Hi All,
Not bad for the first reception. Near the end of TX the signal degraded slowly.
John
Old 04-06-2005, 15:58   #43
it is no pleasure for me to listen to BR-B5akt! There are many
drop outs also during daylight inspite of an 9+ signal, with
a well looking Impulse Response and no interference.
I presume that the
reason is the carrier in the center of the DRM signal which
is approx. 10 db higher than the DRM signal. Hopefully BR will
modify the transmitter avoiding the waste of several kW by
this carrier containing no DRM-informations.
Some months ago I observed test transmissions from DLF on
177 kHz. Time by time they added a carrier in the center of
the DRM signal which immediately lower the SNR by 6 to 7 dB.
For sure the BR engineers know this low effective method to
linearise a transmitter but the financial controllers prefere to
waste money daily instead of investing one time in a
modification which would improve the listening quality for the
customers paying for it.
Old 09-06-2005, 17:23   #44
Hi All,
Poor reception this evening. I stopped log after 1 hour. Look at the "zip" how it started and ended.
John
Old 13-06-2005, 13:17   #45
Diagram looks worse than reception actually was, but many dropouts caused by a.m. interference from 10kHz down and selective fading.
