Old 22-11-2019, 13:56   #1126
RFI 3965 kHz reception near Atlanta, Georgia, USA
Overnight (2h59m) reception of the RFI 1 kW signal - no audio decoding, about 6 dB max SNR.
Old 22-02-2020, 17:12   #1127
Solid reception, Multimedia was on, but no data inside:
Old 24-02-2020, 13:15   #1128
Signal getting weaker after 10 UTC:
Old 29-02-2020, 13:27   #1129
Hello
To moment 14h00 UTC I receive MOT picture from RFI 3965 Khz :
https://nsa40.casimages.com/img/2020...3939180322.jpg
Old 29-02-2020, 15:35   #1130
Originally Posted by MARCEL
Hello
I tried later at 16h UTC.
The MOT Slide Show was and still is in receiving status green,
but no pictures received. 0/0
Problem with my DReaM or do they most time transmit no pictures?
Old 29-02-2020, 15:37   #1131
[quote=MARCEL]Hello
https://nsa40.casimages.com/img/2020...4092578542.jpg
https://nsa40.casimages.com/img/2020...5816455589.jpg
https://nsa40.casimages.com/img/2020...0514471149.jpg
Old 29-02-2020, 18:25   #1132
Too much noise pulses from an electric fence in 200m distance:
Old 29-02-2020, 19:56   #1133
Same problem here, Dream panel shows AAC Mono (14.64 kbps) + MM (2.82 kbps), but bringing up slide show viewer shows just an empty box, even when all lights are green. SNR is 19.3db so plenty of signal.
Good catch Marcel! :-)
Old 29-02-2020, 22:56   #1134
Friedrich,
Did you use Dream V2? Try V1.6.1 or the DRM-Software Radio instead!
PS: Perhaps I'm wrong. Was it Journaline that spooked?
Old 01-03-2020, 02:11   #1135
I had received the same rotatable antenna picture slide over a month ago using Dream 2.2 externally via a KiwiSDR in the UK. It took a fairly long time to download. If the light is green it is working.
At first I thought it was not working. I then left it alone, with the green light on, and came back much later to see that it had downloaded the picture.
Old 01-03-2020, 15:09   #1136
Picture of 3965 Khz RFI to moment 16H00 UTC.
Old 06-03-2020, 16:19   #1137
Not bad for 1 kW at 668 km distance:
Old 07-03-2020, 07:04   #1138
Unattended overnight log to test stability:
Old 08-03-2020, 12:47   #1139
Almost 95% CDA
Old 08-03-2020, 15:40   #1140
Short test just to create a DRM-Log Plot:
