Old 23-07-2019, 18:36   #76
July_23
A result for 21 mins @ 98.9% CDA / 22.7dB max SNR.
Bad audio quality, only L channel!
Old 29-08-2019, 19:56   #77
Aug_29
A result for 29 mins @ 97.9% CDA / 23.6dB max SNR.
Old 05-09-2019, 18:43   #78
Sept_05
A result for 29 mins @ 99.7% CDA / 24dB max SNR.
Old 06-09-2019, 19:05   #79
Sept_06
A result for 29 mins @ 97.9% CDA / 24.1dB max SNR.
Old 09-09-2019, 18:36   #80
Sept_09
The transmission lasted ~9 mins then TX problems noticed and a final TX breakdown. TX never recovered.
Old 19-09-2019, 18:30   #81
Sept_19
A result for 25 mins @ 98% CDA / 23.5dB max SNR.
Old 21-09-2019, 18:35   #82
Sept_21
Problematic reception due to continuous TX break-downs. Sometime I stopped of logging, too boring...
Old 15-10-2019, 18:32   #83
Oct_15
Until 18:15 the result was perfect, then the signal dropped causing decoding errors. ~81% CDA / 25.9dB max SNR.
Old 29-03-2020, 18:29   #84
March_29
A result for 23 mins @ ~76% CDA / 24.9dB max SNR.
Old 30-03-2020, 18:47   #85
March_30
A more or less typical (bad?) result.
Old 05-04-2020, 18:31   #86
April_05
Mixed results for 28 mins.
Old 06-04-2020, 18:24   #87
April_06
Good reception, 99.98% CDA / 25.8dB max SNR.
Old 08-04-2020, 18:31   #88
April_08
A result for 29 mins @ 98.7% CDA / 24.8dB max SNR.
Old 09-04-2020, 18:24   #89
April_09
A result for 27 mins @ 95.5% CDA / 25.4dB max SNR.
Old 10-04-2020, 19:06   #90
April_10
A result for 26 mins @ ~81% CDA / 24.3dB max SNR.
