Old 23-12-2007, 14:04   #31
Dec. 23
Another unattended log with no good results.
Old 24-12-2007, 14:52   #32
Dec. 24
"My Best wishes to All"
In spite of the strong signal the QRM destroyed many times DRM.
Old 29-12-2007, 14:11   #33
Dec. 29
The VoR and the QRM.
Old 30-12-2007, 13:20   #34
maxpower
Here's a little 15 min log from today with my Low-Cost SDR Testboard.
Sorry, I put in the wrong Frequency when start logging. Its not 12160 but 11615 kHz. SNR max has been 36 dB and SNR average was about 32.84 dB.
Apart from my local qrm problem a very nice and clean signal from Taldom!
Stephan
"Pappradio" 2 SDR / Himalaya 2009, near Leer/Ostfriesland (Web remote-controlled) 15m Long-Wire / Active Deltaloop, Asus Xonar 192 kHz / Realtek HD Soundcard, Atom 330 ITX Mainboard, rural area; 53'10N, 7'27E;
maxpower is offline   Reply With Quote
Old 30-12-2007, 14:25   #35
Ant-SWL
Ant-SWL's Avatar
VoR 11615 KHz
Very good reception today. 82 Min. log with 100% audio. Two dips in SNR by deep fading and a slow RX-AGC. Rapid conditions change at 1436 UTC. Nearly 10 Min. later than on 16. December. The dx-conditions on 11 MHz comes now every day a bit longer again in northern hemisphere.
http://www.drmrx.org/forum/showpost....4&postcount=26
vy 73, Andy
Ant-SWL is offline   Reply With Quote
Old 30-12-2007, 17:08   #36
Dec. 30
A partially unattended log, a very good result in spite of the QRM.
Old 03-01-2008, 14:14   #37
Jan. 03
A partially unattended log, a very good result until QRM affected the decoding.
Old 03-01-2008, 22:07   #38
Thumbs up
perfect results the whole transmission.
carknue is offline   Reply With Quote
Old 04-01-2008, 14:27   #39
Jan. 04
Another problematic result.
Old 06-01-2008, 16:28   #40
CT1ADT
CT1ADT's Avatar
Hi
perfect results...
73s Esteves
Kenwood TS-2000 + vertical antenna R7000 ( 8m )
MyDRMpage: http://www.qsl.net/ct1adt
CT1ADT is offline   Reply With Quote
Old 08-01-2008, 12:12   #41
Jan. 08
One hour with VoR. Sometimes the signal was rather strong and withstood the QRM.
Old 10-01-2008, 15:32   #42
Quite good results today.
Old 11-01-2008, 14:07   #43
Jos
11615 from Taldom 0700-1500
Good results today.
Jos.
Jos is offline   Reply With Quote
Old 11-01-2008, 14:22   #44
Jan. 11
An 115mn auto-log from VoR.
Old 12-01-2008, 11:10   #45
Per
Per's Avatar
Jan 12
Pretty good reception of VoR today. Listening time: 10:47-11:50 UTC. Especially the last hour gave good reception, a total CDA of 88%.
73's Per - SM0ITS
Per is offline   Reply With Quote
