Old 13-01-2015, 05:54   #196
12 Jan 2015 : RRI SNR Tiganesti 5940 kHz
80% decoded audio.
15:00-18:00 UTC Planetary K-index 2+. Local K-index 2.
18:00-21:00 UTC Planetary K-index 2+. Local K-index 2.
Planetary A-index: 10. Solar flux: 160. SWPC Sunspot number: 133.
Sunset 16:18 UTC.
Old 13-01-2015, 22:12   #197
13 Jan 2015 : RRI SNR Tiganesti 5940 kHz
63% decoded audio.
15:00-18:00 UTC Planetary K-index 2+. Local K-index 3.
18:00-21:00 UTC Planetary K-index 2. Local K-index 2.
Planetary A-index: 8. Solar flux: 160. SWPC Sunspot number: 111.
Sunset 16:20 UTC.
Old 15-01-2015, 05:50   #198
14 Jan 2015 : RRI SNR Tiganesti 5940 kHz
70% decoded audio.
15:00-18:00 UTC Planetary K-index 1-. Local K-index 1.
18:00-21:00 UTC Planetary K-index 2-. Local K-index 2.
Planetary A-index: 8. Solar flux: xxx. SWPC Sunspot number: 93.
Sunset 16:21 UTC.
Old 15-01-2015, 17:39   #199
Jan_15
After the SNR peak the signal started dropping and at about 18H24 dropped by 40 dB and almost disappeared, no reason to continue logging.
Old 17-01-2015, 15:54   #200
16 Jan 2015 : RRI SNR Tiganesti 5940 kHz
61% decoded audio.
15:00-18:00 UTC Planetary K-index 0+. Local K-index 1.
Planetary A-index: 6. Solar flux: 127. SWPC Sunspot number: 62.
Sunset 16:25 UTC.
Old 18-01-2015, 07:18   #201
17 Jan 2015 : RRI SNR Tiganesti 5940 kHz
68% decoded audio.
15:00-18:00 UTC Planetary K-index 0. Local K-index 0.
18:00-21:00 UTC Planetary K-index 1-. Local K-index 0.
Planetary A-index: 7. Solar flux: 122. SWPC Sunspot number: 75.
Sunset 16:25 UTC.
Old 18-01-2015, 17:54   #202
Jan_18
The known scenario. Not surprised for the result. (BTW the RF signal sometime reached 75 dBuV).
Old 18-01-2015, 20:44   #203
18 Jan 2015 : RRI SNR Tiganesti 5940 kHz
22% decoded audio.
18:00-21:00 UTC Planetary K-index 1+. Local K-index 2.
Planetary A-index: 7. Solar flux: 126. SWPC Sunspot number: 49.
Sunset xx:xx UTC.
Old 19-01-2015, 07:55   #204
Mikey
Managed 93.66% Audio Decode. No Idea why it is labelled as 5910 though.
Mikey is offline   Reply With Quote
Old 19-01-2015, 17:37   #205
Jan_19
Weak signal from start, a better result not expected but I gave it a try for 20 mins.
Old 19-01-2015, 19:05   #206
Good reciption this evning. CDA 99.98%ok
Old 19-01-2015, 22:04   #207
19 Jan 2015 : RRI SNR Tiganesti 5940 kHz
63% decoded audio.
15:00-18:00 UTC Planetary K-index 0+. Local K-index 0.
18:00-21:00 UTC Planetary K-index 1-. Local K-index 1.
Planetary A-index: 5. Solar flux: 130. SWPC Sunspot number: 78.
Sunset xx:xx UTC.
Old 21-01-2015, 05:37   #208
20 Jan 2015 : RRI SNR Tiganesti 5940 kHz
70% decoded audio.
18:00-21:00 UTC Planetary K-index 0+. Local K-index 0.
Planetary A-index: 5. Solar flux: 126. SWPC Sunspot number: 62.
Sunset 16:33 UTC.
Old 21-01-2015, 17:28   #209
Jan_21
The reception followed the known scenario. After the SNR peak the signal dropped by ~35 dBs.
Old 21-01-2015, 21:17   #210
21 Ja 2015 : RRI SNR Tiganesti 5940 kHz
38% decoded audio.
15:00-18:00 UTC Planetary K-index 4-. Local K-index 4.
18:00-21:00 UTC Planetary K-index 3. Local K-index 4.
Planetary A-index: 4. Solar flux: 124. SWPC Sunspot number: 57.
Sunset 16:33 UTC.
