Old 27-10-2013, 18:29   #1
RRI 5940 kHz from Tiganesti
I got this transmission from RRI on 5940 kHz for 53 mins in English. Not very good decoding and only the L channel was listenable but the R was barely be heard.
As mentioned in their program schedule: "As of October 27th 2013 RRI broadcasts on new SW frequencies"
06.30 07.00 UTC 9600 kHz (DRM),
18.00 19.00 UTC 5940 kHz (DRM) and
21.30 22.00 UTC 6030 kHz (DRM)
Old 28-10-2013, 19:04   #2
Oct_28
The signal was strong so I got a very good result.
The overwhelming majority of my posted logs, since years ago, were using Dream1.6.1cvs.
For sometime now I use for testing Dream2.1.
I noticed that the SNR figures are somewhat different between the two Dream releases (seen on the attached plots) especially on estimating the max SNR figures. Dream2.1 seems that it needs more time to get the SNR changing values than Dream1.6.1. This leads to wrong figures by ~2.5dB or more.
Any explanations?
Old 02-11-2013, 19:11   #3
Nov_02
The results were perfect (max SNR >33 dB) until 18:37, then the signal dropped by 20 dBs and decoding problems started.
Old 03-11-2013, 18:47   #4
Nov_03
The results were perfect except of a short TX break down.
Old 04-11-2013, 18:37   #5
Nov_04
After 30 mins of almost perfect results at 18H30 the DRM signal dropped and low SNR affected the decoding.
Old 07-11-2013, 18:37   #6
Nov_07
Mixed results.
Old 08-11-2013, 19:19   #7
Nov_08
Bad results tonight.
Old 10-11-2013, 18:06   #8
Nov_10
A very good result for 58 mins.
Old 13-11-2013, 18:39   #9
Linux-DRM
RRI 5940kHz - English to Western Europe
Really strong signal tonight, solid reception from start to finish, average SNR was 24dB.
Cap
Radios: MR 27024, 2 x Tecsun PL-660, Eton G3 & E5, Tecsun PL-365
Antenna: Homebrew Magnetic Loop (3-30MHz)
Software: Dream v2.2 (svn924) on Ubuntu 14.04 LTS
Linux-DRM is offline   Reply With Quote
Old 16-11-2013, 18:08   #10
Nov_16
A perfect result (99.99% CDA) for 29 mins.
Old 18-11-2013, 18:11   #11
Nov_18
A newcomer in this log. Strong co-channel QRM, all time long, destroyed the decoding, very bad results.
PS: I wonder if RRI monitors this website.
Old 20-11-2013, 18:10   #12
Nov_20
No QRM tonight and high SNR (33 dBs) except of that around 18H33 the rf signal dropped by >20 dBs and decoding stopped. This has happened again.
Old 30-11-2013, 18:10   #13
Nov_30
Until 18H26 the results were perfect then decoding problems started.
Old 30-11-2013, 18:10   #14
Very strong signal stringth from SNR S9+20db=54dbuV.Log 38min.
Old 01-12-2013, 18:06   #15
Dec_01
A result for 34 mins.
