Old 02-12-2016, 05:46   #31
1 Dec 2016 : RRI on 7350 kHz from Tiganesti
89% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index: 0. Local K-index: 0.
18:00-21:00 UTC Planetary K-index: 0. Local K-index: 0.
Planetary A-index: 3. Solar flux: 84. SWPC Sunspot number: 75.
Sunset 15:57 UTC.
Old 03-12-2016, 05:41   #32
2 Dec 2016 : RRI on 7350 kHz from Tiganesti
99% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index: 1. Local K-index: 2.
18:00-21:00 UTC Planetary K-index: 1. Local K-index: 2.
Planetary A-index: 3. Solar flux: 85. SWPC Sunspot number: 49.
Sunset 15:56 UTC.
Old 04-12-2016, 06:06   #33
3 Dec 2016 : RRI on 7350 kHz from Tiganesti
99+% decoded audio during the transmission.
Planetary A-index: 4. Solar flux: 86. SWPC Sunspot number: 59.
Sunset 15:56 UTC.
Old 05-12-2016, 06:00   #34
4 Dec 2016 : RRI on 7350 kHz from Tiganesti
76% decoded audio during the transmission.
Planetary A-index: 3. Solar flux: 88. SWPC Sunspot number: 62.
Sunset 15:55 UTC.
Old 06-12-2016, 06:13   #35
5 Dec 2016 : RRI on 7350 kHz from Tiganesti
96% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index: 1+. Local K-index: 1.
18:00-21:00 UTC Planetary K-index: 1. Local K-index: 1.
Planetary A-index: 2. Solar flux: 84. SWPC Sunspot number: 37.
Sunset 15:55 UTC.
Old 07-12-2016, 05:33   #36
6 Dec 2016 : RRI on 7350 kHz from Tiganesti
85% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index: 2+. Local K-index: 2.
18:00-21:00 UTC Planetary K-index: 1+. Local K-index: 2.
Planetary A-index: 4. Solar flux: 81. SWPC Sunspot number: 37.
Sunset 15:55 UTC.
Old 08-12-2016, 05:31   #37
7 Dec 2016 : RRI on 7350 kHz from Tiganesti
93% decoded audio during the transmission.
Planetary A-index: 7. Solar flux: 78. SWPC Sunspot number: 24.
Sunset 15:55 UTC.
Old 09-12-2016, 05:43   #38
8 Dec 2016 : RRI on 7350 kHz from Tiganesti
Only 46% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index: 4. Local K-index: 4.
18:00-21:00 UTC Planetary K-index: 4+. Local K-index: 5.
Planetary A-index: 11. Solar flux: 75. SWPC Sunspot number: 18.
Sunset 15:54 UTC.
Old 10-12-2016, 20:40   #39
9 Dec 2016 : RRI on 7350 kHz from Tiganesti
15:00-18:00 UTC Planetary K-index: 4-. Local K-index: 4.
18:00-21:00 UTC Planetary K-index: 5-. Local K-index: 5.
Planetary A-index: 23. Solar flux: 73. SWPC Sunspot number: 14.
Sunset 15:54 UTC.
Old 26-12-2016, 17:39   #40
After a few strong minutes the propagation conditions were gone:
Old 23-01-2017, 11:51   #41
SNR Tiganesti E2 with adjacent adjacent channel AM splatter on 7.355 MHz. Gave up at 18:18 UTC. Max. 11.94 dB SNR and 1.56% decoded audio
Old 29-01-2017, 19:30   #42
DRM Hdn
DRM Hdn's Avatar
Today's reception was severely impaired by fading and neighboring AM station on 7340 kHz. From 18:25 o'clock was an AM transmitter to record below, no DRM reception thus possible. 18:39 o'clock Dream Software chrashes...
File Type: jpg DRM Signal with AM Overlay on 7350 at 18.26 UTC.jpg (44.4 KB, 105 views)
Old 16-03-2017, 20:11   #43
DRM Hdn
DRM Hdn's Avatar
The today's broadcasting was interrupted three times by short transmitter failure.
At the first break i stopped the log and restartet new as i saw the transmission goes on.
You can see the second and third transmission break in the second log.
Old 30-10-2017, 16:59   #44
29 Oct 2017 : RRI on 7350 kHz from Tiganesti
It's good to see the return of the one hour, English, early evening DRM transmission from RRI, as it was missing from A17. The DRM started about ten minutes late and there was 80% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index: 0+. Local K-index: 0.
18:00-21:00 UTC Planetary K-index: 1-. Local K-index: 1.
Planetary A-index: 6. Solar flux: 77. EISN Sunspot number: 24.
Sunset 16:41 UTC.
Old 31-10-2017, 16:42   #45
30 Oct 2017 : RRI on 7350 kHz from Tiganesti
There was 66% decoded audio during the transmission.
Planetary A-index: 4. Solar flux: 75. EISN Sunspot number: 12.
Sunset 16:39 UTC.
