Old 01-11-2017, 20:36   #46
1 Nov 2017 : RRI on 9770 kHz from Tiganesti
There was 99+% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 0+. Local K-index: 1.
06:00-09:00 UTC Planetary K-index: 0+. Local K-index: 1.
Planetary A-index: 3. Solar flux: 75. EISN Sunspot number: 0.
Sunrise 06:57 UTC.
Old 02-11-2017, 18:50   #47
Perfect reception.
Old 05-11-2017, 06:49   #48
4 Nov 2017 : RRI on 9770 kHz from Tiganesti
03:00-06:00 UTC Planetary K-index: 1-. Local K-index: 1.
06:00-09:00 UTC Planetary K-index: 0+. Local K-index: 0.
Planetary A-index: 9. Solar flux: 73. EISN Sunspot number: 0.
Sunrise 07:02 UTC.
Old 05-11-2017, 20:39   #49
5 Nov 2017 : RRI on 9770 kHz from Tiganesti
There was only 55% decoded audio during the transmission, looks like it was on low power for the first half of the transmission!
06:00-09:00 UTC Planetary K-index: 1-. Local K-index: 1.
Planetary A-index: 4. Solar flux: 72. EISN Sunspot number: 0.
Sunrise 07:04 UTC.
Old 06-11-2017, 21:17   #50
6 Nov 2017 : RRI on 9770 kHz from Tiganesti
There was 100% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 0. Local K-index: 0.
Planetary A-index: 2. Solar flux: 71. EISN Sunspot number: 0.
Sunrise 07:06 UTC.
Old 07-11-2017, 19:45   #51
7 Nov 2017 : RRI on 9770 kHz from Tiganesti
03:00-06:00 UTC Planetary K-index: 2+. Local K-index: 2.
06:00-09:00 UTC Planetary K-index: 3+. Local K-index: 2.
Planetary A-index: 2. Solar flux: 70. EISN Sunspot number: 0.
Sunrise 07:07 UTC.
Old 08-11-2017, 20:50   #52
8 Nov 2017 : RRI on 9770 kHz from Tiganesti
There was 95% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 6+. Local K-index: 5.
06:00-09:00 UTC Planetary K-index: 3. Local K-index: 3.
Planetary A-index: 36. Solar flux: 69. EISN Sunspot number: 0.
Sunrise 07:09 UTC.
Old 09-11-2017, 21:51   #53
9 Nov 2017 : RRI on 9770 kHz from Tiganesti
There was 93% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 3+. Local K-index: 2.
06:00-09:00 UTC Planetary K-index: 2+. Local K-index: 2.
Planetary A-index: 47. Solar flux: 67. EISN Sunspot number: 0.
Sunrise 07:11 UTC.
Old 10-11-2017, 14:00   #54
10 Nov 2017 : RRI on 9770 kHz from Tiganesti
There was 86% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index: 4-. Local K-index: 2.
Planetary A-index: 20. Solar flux: 66. EISN Sunspot number: 0.
Sunrise 07:13 UTC.
Old 12-11-2017, 06:59   #55
11 Nov 2017 : RRI on 9770 kHz from Tiganesti
There was 92% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index: 2-. Local K-index: 1.
Planetary A-index: 21. Solar flux: 71. EISN Sunspot number: 0.
Sunrise 07:14 UTC.
Old 12-11-2017, 18:27   #56
The listed azimuth of this broadcast in the HFCC database, i.e. 307 degrees, has me a bit puzzled ... This signal does appear to be generally stronger to the west than the one from Galbeni which certainly should be the case.
Old 12-11-2017, 21:03   #57
12 Nov 2017 : RRI on 9770 kHz from Tiganesti
03:00-06:00 UTC Planetary K-index: 2-. Local K-index: 1.
06:00-09:00 UTC Planetary K-index: 1+. Local K-index: 1.
Planetary A-index: 8. Solar flux: 68. EISN Sunspot number: 0.
Sunrise 07:16 UTC.
Old 14-11-2017, 12:07   #58
13 Nov 2017 : RRI on 9770 kHz from Tiganesti
There was 99% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 3-. Local K-index: 2.
Planetary A-index: 6. Solar flux: 70. EISN Sunspot number: 0.
Sunrise 07:18 UTC.
Old 14-11-2017, 19:54   #59
14 Nov 2017 : RRI on 9770 kHz from Tiganesti
03:00-06:00 UTC Planetary K-index: 3-. Local K-index: 3.
06:00-09:00 UTC Planetary K-index: 2. Local K-index: 1.
Planetary A-index: 6. Solar flux: 72. EISN Sunspot number: 14.
Sunrise 07:19 UTC.
Old 15-11-2017, 19:32   #60
15 Nov 2017 : RRI on 9770 kHz from Tiganesti
There was 85% decoded audio during the transmission.
Planetary A-index: 11. Solar flux: 75. EISN Sunspot number: 14.
Sunrise 07:21 UTC.
