Old 05-11-2016, 04:54   #1
RRI on 6145 KHz
I found this 05H00 UTC transmission in a unidentified language.
Good 20.96 Kbps signal with a too aggressive audio.
95% audio.
At 06H00 transmission switched to 6040 KHz in French
Old 05-11-2016, 06:33   #2
Hi Laurent,
Looking at the HFCC database, at this time and frequency, there is an analogue transmission from Galbeni in Romanian at a azimuth of 285 degrees. I wonder if this was it in DRM rather than AM?
Old 07-11-2016, 04:38   #3
Hi Neil
I tried again this morning It is definitely DRM
Language might well be Romanian As they speak quite fast
Old 11-11-2016, 04:59   #4
9 Nov 2016 : RRI on 6145 kHz from Galbeni
99% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 0. Local K-index: 0.
06:00-09:00 UTC Planetary K-index: 2. Local K-index: 2.
Planetary A-index: 3. Solar flux: 77. SWPC Sunspot number: No data available.
Sunrise 07:12 UTC.
Looking at the Romanian page of the RRI web site, I see there is a daily DRM transmissions from 05:00 to 06:00 UTC in Romanian.
Old 21-11-2016, 20:46   #5
A partial log from Nov 20, 2016 ...
Old 01-12-2016, 19:15   #6
Mainly posted for grins ... I had a bit of spare time on my hands ...
Old 23-12-2016, 03:47   #7
MER MAX in Brazil: 14 dB, from Galbeni TX1. No decod.
Old 06-01-2017, 04:37   #8
6 Jan 2016. 9dB MER MAX. 5:20 UTC, no decode. 300 KW from Galbeni TX1. 73!
Old 15-01-2017, 06:08   #9
Perfect reception in Stockholm.
Old 18-01-2017, 04:56   #10
Perfect reception again this morning. The SNR is rather poor, even that the CIR was very good.
Old 31-01-2017, 07:57   #11
DRM Hdn
DRM Hdn's Avatar
31 Jan 2017 RRI on 6145 kHz from Galbeni
Since the last days is the reception condition very strange at the first 20-30 min of broadcasting the romanian program from galbeni. i have no idea for the reason.
at 05:34UTC goes the reception in normally conditions until the end of transmitting this morning.
weeks before was galbeni hearable from beginning of DRM transmitting.
You can see the reception result in 2 parts. 1: 05:00 - 05:26 UTC | 2: 05:28-05:50 UTC.
Very interesting to see how the gainline increases in picture 2...
Old 01-02-2017, 20:49   #12
Jan 30th log ...
Old 11-02-2017, 07:24   #13
DRM Hdn
DRM Hdn's Avatar
11 Feb 2017 RRI on 6145 kHz from Galbeni
A better reception result this early morning as the days before on this frequency.
Old 17-03-2017, 08:00   #14
DRM Hdn
DRM Hdn's Avatar
17 Mar 2017 RRI on 6145 kHz from Galbeni
Good reception result this morning.A transmission interrupt was at the beginning of the romanian broadcast to recognize.
Old 25-03-2017, 04:41   #15
I wonder why they use this over clipped audio.
At this early time tuning to their signal is not the best way to wake up all your family.
