Old 01-11-2006, 13:44   #16
f1tay
Reception at Paris.
Old 01-11-2006, 14:42   #17
hsseppo
RNZI in Helsinki, pretty good.
Seppo
hsseppo is offline   Reply With Quote
Old 01-11-2006, 15:47   #18
Not too bad for not being in the target area.
Old 02-11-2006, 11:14   #19
Thumbs up Nov.02
Her is log of 238min . today. Very good prppagation and nice program from RNZI. Only QRM from Guam AM . Very strong S9+10db and stabile signal.
Old 03-11-2006, 14:25   #20
fibber
fibber's Avatar
Roller Coaster Ride
Several 1 hr chunks of 99%+ but the rest is up and down.
Elad FDM-S1, HCJB Pappradio, Newstar DR111.
DReaM, DRM Software Radio.
JTV680 Vertical, 80M 1/2 Wave Dipole.
Christopher - "Fibber" - K6FIB
Salem, Oregon, USA
44.901951 -123.048109
CN84lv
DRM in North America? Join DRMNA!
http://groups.yahoo.com/group/drmna
or read the blog http://www.drmna.info
fibber is offline   Reply With Quote
Old 03-11-2006, 15:11   #21
Nov.03
Log today is only 113min. I must switch of for work.
Old 03-11-2006, 16:35   #22
DRT1 with L-antenna
Switched between DREAM 1.6.1 and older WinRadio DRM 1.2.5.
Somehow could not merge the txt files with the slightly different format, so here a little wider graphic.
Obviously the newer DREAM decodes much better than the older WinRadio version, even when using the integrated notchfilter.
Old 04-11-2006, 14:09   #23
a short log from today.
Old 04-11-2006, 14:26   #24
Thumbs up Nov.04
Hi.
LOg from start 0800UTC to 1200UTC. This time start very strong AM on 9875Khz and RNZI brake down. 225MIn.
Old 05-11-2006, 08:57   #25
Nov 5
Better reception than what the calculation gives.
Nice to pick up Radio New Zealand International - The Voice of the Pacific, as the text msg reads.
Old 05-11-2006, 11:02   #26
Andreas
Junior Member
Andreas's Avatar
Best around midnight (in New Zealand ) unless there is no interference (including self made one).
BtW an indoor mounted (!) DX-10 antenna was used.
Andreas is offline   Reply With Quote
Old 05-11-2006, 13:35   #27
Thumbs up Nov.05
Very good signal from RNZI today but only problem from TWR from Guam .
225min. Log.
Old 07-11-2006, 17:26   #28
MOBILE RECEPTION
48712 Gescher-B525-A43-A1-59368 Werne in northwestern Germany.
Here also problems after 09:30 UTC with interference from AM 5kHz down.
Old 09-11-2006, 00:40   #29
I don't know what happened with the transmission schedule.Didn't they say 9890kHz at this time? 9870kHz starting from 1200 UTC is plagued with severe ajacent channel interference which is a religious program of chinese language.
BTW: I have done some tinkering with Dream decoding algorithm, otherwise the successfully decoded audio frame would be even fewer.
Old 09-11-2006, 13:28   #30
CT1ADT
CT1ADT's Avatar
Hi
Very good signal from RNZI today in 9890kHz
73s Esteves
Kenwood TS-2000 + vertical antenna R7000 ( 8m )
MyDRMpage: http://www.qsl.net/ct1adt
CT1ADT is offline   Reply With Quote
