Old 02-08-2012, 21:07   #91
Weak RF signal at times made decoding difficult on the DR111.
Old 03-08-2012, 18:56   #92
The enclosed log is a bit messy, but I wanted to show that the DR111 performs much like my "main" receiver, the Yaesu FRG-7700.
The red curve is the DR111 SNR. It peaked at 28 dB.
The yellow curve is the FRG-7700. It peaked at 37.6 dB.
The thicker blue line is the decoded audio from the DR111, about 76%.
The thinner line is the FRG-7700, which decoded 72% audio (!).
In the beginning the TX was rather strong, followed by a weaker period until it picked up again. Interesting is that the decoded audio is roughly the same. So the DR111 is rather a good performer.
RUVR runs Mode C for the time being and only one service, not two like they used to do.
Old 04-08-2012, 13:19   #93
Newstar DR111
Now they are running 9 kbps on this frequency too...
Today I used an external antenna to the DR111, just a simple contraption about 8 meters long wire thrown out from a window.
Old 05-08-2012, 13:33   #94
Mikey
Suprisingly stable signal today. Only a couple of dropouts but audio quality does not sound as good as last
time I listened. SNR on the DR111 hardly ever going above one bar.
Old 06-08-2012, 15:38   #95
ianf
I took had really good results today, with Newstar and PKs Loop aerial, agreed on 1 bar, but went up to 4 bars, the audio here Devon was really good
Old 10-08-2012, 10:14   #96
ianf
Newstar DR111 and PKs Loop SW620
Great reception, virtually no dropouts this morning, would post logs, but only have access to a Mac here
Old 10-08-2012, 12:54   #97
Newstar DR111
Unfortunately, the signal is not very strong in my direction, and the reception therefore suffers.
Old 11-08-2012, 14:12   #98
Mikey
Picked up last half hour. Much better audio quality 13.6 kbps much beeter than previous. SNR between 16 min and 26 Max.
Old 13-08-2012, 21:31   #99
brouillage
I appreciate as well that the VoR has ceased dual transmissions. But most of their broadcasts are suffering still from weak transmission power. 15 kW is not enough.
brouillage is offline   Reply With Quote
Old 18-08-2012, 13:42   #100
Newstar DR111
I forgot that I had set the sleep timer in the DR111, so here are two logs (both with the sleep timer). Therefore both are only about 30 minutes each. 92.6% and 99.8% CDA.
Old 21-08-2012, 13:25   #101
Newstar DR111
153 minutes with 91.3% decoded audio.
Old 24-08-2012, 15:20   #102
ianf
Good reception today, with the odd break in E Devon
Old 30-08-2012, 13:01   #103
My second Newstar DR111 with telescopic antenna
Only 62% CDA, but from 11 UTC local thunderstorms may have interfered.
Old 09-09-2012, 13:42   #104
This transmission used to be a lot better some years ago...
Old 16-09-2012, 13:33   #105
Bonito RadioJet
SNR Maximum [dB]: 40.9
