Old 19-07-2011, 14:27   #76
A long but unstable log with a not so convincing result. The max. SNR was 37.16 dB, which happened twice - hi. The signal strength varies a lot here.
Old 20-07-2011, 08:12   #77
dadalbinder
Service 1A, 1B
9850 this morning:
1A language English
1B language Russian or Serbian
Greetings
W. Hartmann
Old 20-07-2011, 09:36   #78
dadalbinder
Englisch and Russian Audio Service
it seems for me, that only Fraunhofer Software version 2.0.38 is really able to give audio in both languages.
In SoDiRa one can only get the first service.
DREAM 14.1 seems not to be able to get sufficient audio.
Who is experienced enough to give more informations?
Greetings
W. Hartmann
Old 20-07-2011, 10:13   #79
The Dream 1.6.1cvs plays both channels, but I cannot get the Multimedia. I get an error message: "Error: expected NML Code 0x02, got 0x03"
The DRM S/W Radio also plays both channels, but I cannot get the Multimedia, in "DRM MM viewer": "Failed to create empty document".
The SoDiRa Version: 0.083 seems only possible to listen to the 1st channel.
Only the last 30 minutes of the log were more or less perfect.
Sorry, the Frames in the log is 750, not 1500.
Old 21-07-2011, 11:36   #80
A very variable result indeed. Max. SNR 39 dB.
Old 22-07-2011, 17:27   #81
Both good and bad reception. The bad is mainly caused by low signal strength.
Old 24-07-2011, 14:00   #82
Here also strong fading and at first AM interference.
Old 24-07-2011, 16:23   #83
About 99.3% CDA today. The best log so far, but shorter than the previous logs.
Old 25-07-2011, 15:09   #84
Some decoding problems around 1055 UTC otherwise almost perfect. Journaline works with Dream 1.13 with Cyrillic and English. But no sound.
Old 03-08-2011, 20:07   #85
Today was not good at all...
Old 05-08-2011, 12:08   #86
Better result today, but a high SNR is needed to get continuous audio. A lot of interruptions in the audio.
Old 15-10-2011, 11:01   #87
Wink Oct 15
Excellent reception of this dual language service from VoR.
I listened to channel 2 (1B) i.e. German. Time: 10:22 - 10:54 UTC. Result: 99.5 % CDA. But the audio quality could definitely be improved. But considering 8.2 kbps, I guess this is what you get.
Old 23-10-2011, 08:23   #88
Oct 22
Also this day excellent reception of VoR.
Was the program a repeat from Oct 15? Same discussion about abortion in Russia.
Old 14-04-2012, 13:42   #89
Good reception but the signal weakened around 0915 UTC.
Old 27-04-2012, 12:51   #90
I traced this TX on 9850 kHz at 12:30, can't decode it due to strong QRM, where is it from and what is the target? it is not scheduled.
Correction
: I found a new schedule update dated 27/4/12... Now it is scheduled
