Old 26-11-2008, 13:21   #31
BBC & DW Test 6130 Sin
Two logs, one with "Deutsche Welle" and one with "BBC & DW Test". Both are short, but almost perfect.
Old 26-11-2008, 13:26   #32
BBC & DW Test 9610 Sin
A log with some trouble. At the beginning the label read "BBC & DW Test", then there was a break and when it came back the label read "Deutsche Welle". Around 0849 the label changed to "BBC & DW Test" again. The "Test" was on in Mode A; the "DW" was in Mode B.
The reception as such on this frequency was perfect, despite that there was a carrier on the channel for a while, but this did not kill the DRM.
Old 26-11-2008, 15:12   #33
BBC & DW Test 9545 Wof / Skn
Perfect from both locations, except for the very last minutes, when the propagation suddenly worsened and the signal strength suddenly got weaker.
Old 26-11-2008, 15:57   #34
BBC & DW Test 13590 Sin
Log start 1450UTC very good propagtion today from Sines it was 64dbuV ,but under time go signal stringth down for sunset is 1550UTC .Under grey line is signal stringth only 10dbuV, only small drop out this time. 1550 utc up to 54dbuV again. MODE A in this condition is no problem.
Old 26-11-2008, 16:03   #35
5995 kHz
Quite good apart from the Tx break.
Old 26-11-2008, 16:04   #36
BBC & DW Test 5895 Kvi
Pretty good result tonight for this frequency!
Old 26-11-2008, 16:05   #37
9610 kHz
Good results apart from Tx/ datastream problems.
Old 26-11-2008, 16:08   #38
9545 kHz Wof/Skn
Not as good as yesterday.
Old 26-11-2008, 16:09   #39
5895 kHz Kvi
Quite good results, no problems like yesterday.
Old 26-11-2008, 17:16   #40
Nov. 26 (3995)
That's a result for 90 mins. A QRM appeared at the left edge of DRM signal affecting only the SNR figure, it lasted until 18:00.
Old 26-11-2008, 17:29   #41
9610 kHz in NZ
Hi All
9610 kHz good at times here in NZ last night, but mostly poor.
73 Chris
Old 26-11-2008, 17:31   #42
9545 kHz in NZ
But 9545 kHz was no good at all :-( Too much co-channel QRM I think.
73 Chris
Old 26-11-2008, 22:57   #43
andimik
13810 Sin
Seems nobody checked the perfect 13810 ...
From 8:49 label and mode changed to Mode A and BBC & DW test
EPG was empty?? AFS has two frequencies.
andimik is offline   Reply With Quote
Old 27-11-2008, 03:54   #44
3995 kHz Skn/ Sin
Good results last night from both sites.
Old 27-11-2008, 04:34   #45
BBC & DW Test 3995 Skn
Perfect from Skelton last night.
