Old 30-04-2008, 22:13   #61
maxpower
Better here and better than yesterday again. But a dream-crash prevented a log over the whole time.
Best signal again after 22.00 UTC
Stephan
Old 01-05-2008, 05:58   #62
Pretty good results last night (was similar the night before).
Old 01-05-2008, 08:53   #63
The DRMSWR is wrong, I got one second (!) decoded audio.
Old 01-05-2008, 22:01   #64
Nothing here tonight.
Old 01-05-2008, 22:52   #65
Not too bad here, 99,97% CDA for 52 minutes.
Signal was peaking about S9+10dB showing the lower ends of the shoulders then.
Looks as if the Tx linearity was not very good.
Frequency still is about 92 Hz too low.
The time window for the german transmission seems to be OK.
Old 02-05-2008, 07:30   #66
maxpower
Hi all!
Looks like my Elektor 2004 RX is clearly inferior to Fritz's Equipment.
Good parts between 21.18 and 21.45 UTC.
Stephan
Old 02-05-2008, 20:11   #67
High frequencies are down here tonight, I'm gone for 160m.
@ Stephan: You're doing very fine with that equipment, the Flex5000A is a much more complex (expensive) machine.
Old 02-05-2008, 20:50   #68
Someone mentioned "I like straight lines", but I cannot agree in this case....
I'm gone for the "2-meter" instead ... That thing in the bedroom on four legs
Old 03-05-2008, 07:57   #69
Nothing here again.
Old 04-05-2008, 15:57   #70
Results from an unattended log last night, btw nothing here also the night before.
Old 04-05-2008, 21:08   #71
I have to hit the sack, but here is the result up until 21:05, which is a meager 37% CDA. Either 15 MHz is no good for my location, or I do not know...
Old 05-05-2008, 05:59   #72
Bad results again last night.
Btw, I dont think the new configuration has any advantages, but currently it is more a problem of propagation anyway.
Old 05-05-2008, 20:58   #73
Tend to agree with Simone's comment from yesterday... But unfortunately, this is no fun...
Old 06-05-2008, 03:49   #74
Good results for 35 minutes in the second hour, but not much for the rest of the time
Old 07-05-2008, 06:14   #75
Conditions improved in the second hour.
