Old 25-11-2008, 06:07   #1
Nov. 25
A weak signal in a noisy environment with a chaotic IR gave the attached result.
EDIT: A new thread has been opened for this test, please move the post there.
Thanks.
Post moved, Simone
Old 26-11-2008, 22:57   #2
andimik
13810 Sin
Seems nobody checked the perfect 13810 ...
From 8:49 label and mode changed to Mode A and BBC & DW test
EPG was empty?? AFS has two frequencies.
andimik is offline   Reply With Quote
Old 27-11-2008, 03:54   #3
3995 kHz Skn/ Sin
Good results last night from both sites.
Old 27-11-2008, 04:34   #4
BBC & DW Test 3995 Skn
Perfect from Skelton last night.
Old 27-11-2008, 06:06   #5
Nov. 26 (3995)
Here's an overnight mostly unattended log with the usual morning problems.
Old 27-11-2008, 06:55   #6
kc2eni
Hello all from the USA!
9545KHz yesterday was DFQ all day with 100% decode. No logs attained here due to apathy on my part. I got up too late to try 6130KHz.
This morning (it's 2:50am here!) 6130KHz is DFQ with 100% decode. I'm using my Elektor radio.
We can usually get anything from Sines here on the East Coast pretty reliably. It also seems that Wooferton does well here on 31M too.
Mark (AKA G7LTT)
http://www.g7ltt.com/drm/
kc2eni is offline   Reply With Quote
Old 27-11-2008, 07:09   #7
BBC & DW Joint Test 5990
Last 10min log from Kvitsoy but not condition for DRM from this transmitter to Sweden .
Old 27-11-2008, 07:22   #8
Nov. 27 (6130)
Good signal and a perfect result.
Old 27-11-2008, 09:07   #9
Nov. 27 (9610)
Some TX related problems at start-up, then almost perfect. A very stable signal at about 35 dBuV.
Old 27-11-2008, 11:12   #10
BBC & DW Test 9545
Not so good propagtion from wofferton today and so CRI on 9540 and 9550 !!!
Log 117min.
Old 27-11-2008, 12:43   #11
Steve Martin
Steve Martin's Avatar
Hello. I'm an editor at the BBC and am working with Julian and colleagues on the new BBC & DW channel.
I would be very keen to hear comments, however subjective, about the sound quality, especially in comparison with other DRM services you may receive.
Today we've made the audio stereo (the coder always indicated stereo but now the audio source genuinely is too) and have made what we believe to be improvements to the audio processing.
You may disagree of course so please don't hold back. We'd be really appreciative of your feedback.
With thanks in anticipation,
Steve.
Steve Martin is offline   Reply With Quote
Old 27-11-2008, 12:58   #12
If you are new to this forum and want to register, please have a look here
Old 29-11-2008, 08:58   #13
kc2eni
For my money I'd like to see an increase of the audio bandwidth. Perhaps you could ditch the P-Stereo in favour of a single wider audio channel instead of 2 skinnier ones.
Program content could also be improved. If the test was indicative of the programming content it is very one sided in favour of DW. Even then they chose to offer the same program repeatedly on all the HF outputs I could hear.
Perhaps an alternating of BBC/DW would be better? Here in the US we can hear Wooferton and Sines very well as probably does the rest of Europe. It's quite possible that listeners would follow any frequency change and therefore would like to hear some variety.
Other than that it was OK.
Mark
Old 30-11-2008, 14:42   #14
Mark
Hi Mark,
I think there were a few changes to the schedule after Julianīs post, so there were more hours from BBC WS, especially 1800- 2300 UTC was not solely DW .
Old 30-11-2008, 19:29   #15
pb1
Most importantly, they broadcasted Newshour at 22 CET.
pb1 is offline   Reply With Quote
