Old 24-02-2019, 23:51   #46
24th Feb. 2019
China National Radio logged for 219 minutes from 0521-0900 UTC. Max. 25,78 dB SNR and 98,91% decoded audio.
Old 28-02-2019, 00:06   #47
26th Feb. 2019
China National Radio logged for 183 minutes from 0556-0900 UTC. This transmission was logged with a not properly tuned EH-Antenna, not the active antenna as seen in the plot. Max. 27,00 dB SNR and 99,72% decoded audio.
Old 10-03-2019, 00:30   #48
9th March 2019
Two logs:
1. China National Radio logged for 46 minutes from 0646-0733 UTC. Max. 26,23 dB SNR and 99,06% decoded audio.
2. China National Radio logged for 75 minutes from 0745-0900 UTC. Max. 26,18 dB SNR and 99,81% decoded audio.
For these two logs I used an EH-Antenna, an EH-Star, tuned to 11695 kHz. The EH Antenna, scorned by many - but works very well - if you know how to use it, is much quieter than the active antenna. It produced almost the same S-meter readings as the active antenna. A drawback is that the usable bandwidth is very narrow.
Old 19-03-2019, 02:29   #49
18 Mar. 2019
China National Radio logged for 94 minutes from 0726-0901 UTC. Max. 25,79 dB SNR and 99,73% decoded audio.
Old 24-03-2019, 00:41   #50
23 Mar. 2019
China National Radio logged for 469 minutes from 0111-0902 UTC. Max. 25,01 dB SNR and 94,09% decoded audio. Perfect reception with 99.97% decoded audio from 0547-0900 UTC.
Old 28-03-2019, 00:49   #51
26-27 Mar. 2019
I used the Gospell GR-216 with an EH Antenna tuned to 11,7 MHz for a change:
China National Radio logged with Gospell GR-216 for 127 minutes from 0653-0859 UTC. Max. 28,00 dB SNR and 98,39% decoded audio.
China National Radio logged with Gospell GR-216 for 89 minutes from 0731-0900 UTC. Max. 25 dB SNR and 98,17% decoded audio.
Old 19-04-2019, 05:18   #52
11695 kHz tests (?)
CNR are up to something? Good signal on 11695 kHz just after 05 UTC. However there is no reaction in DReaM (see attachment). I also tested with the Gospell using the same antenna and got the same result - no title, no data, no nothing. Are we perhaps entering the era of scrambled DRM?
Old 19-04-2019, 07:12   #53
I have the same result at 06:00 UTC, but I don't think it is scrambled DRM. It look like signal excitation malfunction or some similar problems on Tx site. Just take a look on the spectrum waterfall, you'll notice the 2 out of the 3 frequency pilot tones are significantly weaker than normal.
In the attach file, the upper half is the normal DRM, below is the problematic 11695kHz DRM.
My Rx location: GuangXi Province @ E10636′ N2355′
Old 19-04-2019, 08:58   #54
@zfyoung
Yes, you're right. I looked at the other parameters in Dream and saw that all data were missing. I also noticed that the frequency was on-off-on during the afternoon.
Old 24-04-2019, 01:33   #55
China National Radio logged for 121 minutes from 0658-0859 UTC. Max. 19,00 dB SNR and 83,20% decoded audio. 98.7 % decoded audio from 07:52 until the end.
Old 15-06-2019, 02:32   #56
China National Radio logged for 58 minutes from 0727-0825 UTC. Max. 13,91 dB SNR and 10,69% decoded audio.
According to information, some of their DRM transmitters have been off the air for maintenance. That explains why I have not been able to receive any signals but the propagation is so poor anyway . . . it hardly does not matter!
Old 20-06-2019, 14:38   #57
Hi All,
The Bulgarian DX Blog just reported the following changes:
Frequency changes of CNR-1 in DRM mode effective June 18
Posted: 19 Jun 2019 04:08 AM PDT
CHINA Frequency changes of CNR-1 in DRM mode effective June 18:
0100-0300 NF 17790 KUN 030 kW / 032 deg to EaAs Chinese, ex 15250
0300-0700 NF 21550 KUN 030 kW / 032 deg to EaAs Chinese, ex 15250
0700-0900 NF 17790 KUN 030 kW / 032 deg to EaAs Chinese, ex 15250
0900-1100 NF 9540 KUN 030 kW / 032 deg to EaAs Chinese, ex 15250
But on June 19 no signal on old 15250 & on new 17790, 21550, 9540
http://swldxbulgaria.blogspot.com/
Modified NRD-525G with
Radiokit DRM Decoder Board,
SDRplay RSP-1A, SDR Console v3
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
https://www.ndblist.info
Old 09-07-2019, 04:56   #58
There has been more changes since 20.06.2019. 11695 kHz has been very weak lately but yesterday the signal was there:
China National Radio logged for 34 minutes from 0826-0900 UTC. Max. 22,65 dB SNR and 86,70% decoded audio.
Old 12-07-2019, 21:45   #59
11th July 2019
China National Radio logged for 61 minutes from 0758-0900 UTC. Max. 24,08 dB SNR and 96,00% decoded audio.
Old 15-07-2019, 13:27   #60
China National Radio logged for 105 minutes from 0715-0900 UTC. Propagation is picking up in the 25 meter band from China. Max. 25,29 dB SNR and 97,69% decoded audio.
