Old 29-11-2018, 11:03   #1
Digital and Analog SSTV, Digital Voice
Since there is a dearth of DRM broadcasts worldwide currently, I'll expand the potential list of digital transmissions from mediocre broadcasters to amateur radio operators.
I've been experimenting with DSSTV quite a bit lately. I do NOT like the hybrid mode since it seems to be replacing strictly digital transmissions. I don't have ANY need for an URL on the Spynet. DSSTV should allow the use of steganography which is an important capability in today's world. Here's a link to a paper on steganographic communication over radio:
https://link.springer.com/chapter/10...540-74124-4_14
Currently, I've been experimenting primarily with analog SSTV via MMSSTV and digital SSTV via EasyPal. QSSTV 9.2.6 seems to have problems decoding analog SSTV, but it seems to work alright for decoding digital SSTV transmissions. This problem with analog SSTV via QSSTV is probably due to the rather bizarre method of calibrating the sound-card. I'm also experimenting with DigTRX and FreeDV.
Primary DSSTV frequency in the USA is 14.233 MHz
Primary ASSTV frequency in the USA is 14.230 MHz
Primary DV frequency in the USA is 14.236 MHz, I think.
I've been monitoring lower frequencies as well, but traffic seems much to be significantly less at night. I wonder why.
DSSTV 7.173 MHz
ASSTV 7.170 MHz
DV 7.176 MHz
If you live outside the USA, feel free to post those usable frequencies as well and keep them updated if you can.
P.S. Yes, I'm running the Windows' programs via WINE, http://www.winehq.org, on GNU/Linux. WINE is pretty fabulous software today due to A. Julliard and the rest of the contributors.
Old 03-12-2018, 16:55   #2
DRM-OM
Did you ever have a look at this: http://voaradiogram.net/
greetings ...
Old 03-12-2018, 20:04   #3
Yep. This project is now hosted primarily on http://swradiogram.net. Functionally, it's "analog" SSTV with text. The results are similar too. I don't really know if an acceptable "digital" mode can be found for this project and still use it over analog shortwave. Personally, I'd love to see the day as the DRM standard is also slightly revised to eventually include automatic digital fallback modulation along with the addition of 4 QAM modulation, i.e. 64, 16, 4 QAM and then silence. Personally, I'd like to see the radiogram project effectively compete with DRM, but to do so would almost transform the radiogram project into an already existing digital standard like DRM.
