Old 27-11-2008, 06:06   #46
Nov. 26 (3995)
Here's an overnight mostly unattended log with the usual morning problems.
Old 27-11-2008, 06:55   #47
kc2eni
Hello all from the USA!
9545KHz yesterday was DFQ all day with 100% decode. No logs attained here due to apathy on my part. I got up too late to try 6130KHz.
This morning (it's 2:50am here!) 6130KHz is DFQ with 100% decode. I'm using my Elektor radio.
We can usually get anything from Sines here on the East Coast pretty reliably. It also seems that Wooferton does well here on 31M too.
Mark (AKA G7LTT)
http://www.g7ltt.com/drm/
kc2eni is offline   Reply With Quote
Old 27-11-2008, 07:09   #48
BBC & DW Joint Test 5990
Last 10min log from Kvitsoy but not condition for DRM from this transmitter to Sweden .
Old 27-11-2008, 07:22   #49
Nov. 27 (6130)
Good signal and a perfect result.
Old 27-11-2008, 09:07   #50
Nov. 27 (9610)
Some TX related problems at start-up, then almost perfect. A very stable signal at about 35 dBuV.
Old 27-11-2008, 11:12   #51
BBC & DW Test 9545
Not so good propagtion from wofferton today and so CRI on 9540 and 9550 !!!
Log 117min.
Old 27-11-2008, 12:43   #52
Steve Martin
Steve Martin's Avatar
Hello. I'm an editor at the BBC and am working with Julian and colleagues on the new BBC & DW channel.
I would be very keen to hear comments, however subjective, about the sound quality, especially in comparison with other DRM services you may receive.
Today we've made the audio stereo (the coder always indicated stereo but now the audio source genuinely is too) and have made what we believe to be improvements to the audio processing.
You may disagree of course so please don't hold back. We'd be really appreciative of your feedback.
With thanks in anticipation,
Steve.
Steve Martin is offline   Reply With Quote
Old 27-11-2008, 12:58   #53
If you are new to this forum and want to register, please have a look here
Old 27-11-2008, 13:22   #54
Did anyone decode the EPG data? Unfortunatly, I did not get any program information using DREAM 1.10.6cvs.
The sound is okay, but not as good as HCJB with it's 14 kbps only!
Old 27-11-2008, 15:12   #55
Nov. 27 (9545)
A 6 hour result. The reception from Woofferton gave almost perfect results in spite of the AM QRM. Right after the switch to Skelton, at 15:00, the signal got weak and affected by the QRM. The overall sound impression was quite good.
Old 27-11-2008, 15:28   #56
Some AM QRM but overall a good result.
Old 27-11-2008, 16:11   #57
3995 kHz Sin (Skn?)
Good results again, seemed the second hour was from Skelton, not from Sines as scheduled.
Old 27-11-2008, 16:13   #58
5995 (5990?) kHz
Other than scheduled transmission was on 5990 kHz, not 5995 kHz, so my Rx was tuned to 5995 kHz which probably explains some dropouts.
Old 27-11-2008, 16:15   #59
6130 kHz
Perfect results this morning.
@drmdab: yes, seemed the EPG is not working yet.
Old 27-11-2008, 16:16   #60
Julian
5895 From Kvitsoy
did anyone manage to decode audio on 5895 between 16:00 and 17:00 ? we can't tell until we look more deeply if we have an interference or a system problem on this transmission.
cheers
Julian
Julian is offline   Reply With Quote
