Old 28-09-2007, 07:29   #316
27th Sep.
The signal was fine at the beginning, but with a weaker segment from 18:35 - 19:00 UTC.
Old 28-09-2007, 20:02   #317
Ant-SWL
Ant-SWL's Avatar
CVC 17640 KHz
Hi Mathias,
hi all,
from 25. to 28. Sept. the conditions wasnt good for my location:
First 10 Min. decoding and then the signal was drop-down to 10 db SNR and lower. Times of sunspot-minimum
vy 73, Andy
Ant-SWL is offline   Reply With Quote
Old 29-09-2007, 11:54   #318
Generally a weaker signal than during the Summer. No audio towards the end.
Old 01-10-2007, 19:49   #319
Bad tonight here too.
Old 01-10-2007, 20:07   #320
1st Oct.
Not to worry, it was even worse here. OK, I changed to a shorter antenna this afternoon, but it performed better on 17 MHz on the vector analyzer, and I had no urge to go out in the dark and change back to the 13 m antenna.
PS: Even Batman didn't quite make it....
Old 02-10-2007, 20:04   #321
2nd Oct.
Hi Mathias and all,
A bit more audio, please, the level is a bit too low - I think. This log is not the best, but better than yesterday's.
Old 02-10-2007, 20:06   #322
Ant-SWL
Ant-SWL's Avatar
CVC 17640 KHz 02. Okt. 07
Conditions not stable. Up and Downs today.
vy 73, Andy
Old 03-10-2007, 19:30   #323
03 Oct.
Hi Mathias and all.
Small part of signal was pick up her in Sweden this evning.
Old 03-10-2007, 21:01   #324
3rd Oct.
Quite good tonight, 98 % CDA.
Old 04-10-2007, 20:03   #325
4th Oct.
The transmission started late. After a couple of TX start problems it was very good until 1912 UTC, then the signal almost disappeared.
Old 05-10-2007, 19:49   #326
Thumbs up 05 Oct.
Hi Mathias and all.
I switch in freq 1820UTC and no was signal on S4 , log to 1930 . Signal go down to noise in this moment. Very good signal under 60min.
Old 05-10-2007, 20:02   #327
Very much up and down here tonight. Only 37% CDA.
Old 10-10-2007, 20:07   #328
The diagram says it all...
Old 10-10-2007, 20:08   #329
10th Oct.
The first 45 minutes today were perfect with just under +30 dBV into the antenna socket, but at 19 UTC the level had sunk to about +22 dBV. At 19:35 UTC the silence was total and the signal was gone completely.
PS: By the way Friedrich, what happened around 18:47 ???
Old 10-10-2007, 20:23   #330
Telspace
Hi to all,
Up's and Down's today.
Denis
Telspace is offline   Reply With Quote
