Old 03-07-2007, 20:04   #151
120 minutes almost, almost perfect reception tonight.
Old 03-07-2007, 20:12   #152
Ant-SWL
Ant-SWL's Avatar
17640 KHz 3 July 2007
Today i tested a longwire about 20m long in north-south direction.
Some QRN and fading here , the last dip was my pc.
vy 73, Andy
Ant-SWL is offline   Reply With Quote
Old 04-07-2007, 20:05   #153
July 4
Low SNR tonight and problematic decoding between 18:47 and 19:33.
Old 04-07-2007, 20:11   #154
4th July
Slightly lower SNR tonight and problematic decoding between 18:17 and 18:41.
Old 04-07-2007, 20:16   #155
CT1ADT
CT1ADT's Avatar
Hi
120 minutes with perfect reception.
73s Esteves
Kenwood TS-2000 + vertical antenna R7000 ( 8m )
MyDRMpage: http://www.qsl.net/ct1adt
CT1ADT is offline   Reply With Quote
Old 04-07-2007, 21:25   #156
I was too late, but the last minutes were perfect.
Old 05-07-2007, 20:04   #157
July 5
Low SNR tonight and decoding problems. Perfect decoding only from 19:00 to 19:45.
Old 05-07-2007, 20:11   #158
Ant-SWL
Ant-SWL's Avatar
CVC 17640 KHz 05 July 2007
Good and stable here today with max. 25 dB SNR on indoor dipol.
vy 73, Andy
Old 05-07-2007, 20:23   #159
A 6 minute late start, funny conditions in the beginning with about 7 dB SNR, but then it suddenly changed and became quite good. Sometimes the signal was a bit weak, but good reception on the whole.
Old 06-07-2007, 20:05   #160
6th July
A mostly unattended log, but seems to have been pretty good this evening.
Old 06-07-2007, 20:06   #161
Quite good, still some problems with my rx agc,
and I forgot to switch off the 10dB antenna attenuator all the time!
Old 06-07-2007, 20:21   #162
Ant-SWL
Ant-SWL's Avatar
Thumbs up CVC 17640 KHz 6 July 2006
Hi Fritz and all,
100% CDT, 99,94 % CDA !
Im searching for a lost of 00,06 % CDA in my system ...
Very constant today. Compliments to Calera de Tango, Santiago, Chile.
Greetings to Muenster too .
vy 73, Andy
Old 06-07-2007, 20:33   #163
Telspace
Hi to all,
Today's log.
Starting good but last hour was very bad.
Denis
Telspace is offline   Reply With Quote
Old 06-07-2007, 21:38   #164
July 6
A pretty good result tonight, 99.83% CDA.
Old 09-07-2007, 20:03   #165
Telspace
Hi to all,
Today's log.
Denis
