Old 04-12-2018, 00:18   #286
Originally Posted by DRM-OM
I just downloaded successfully
Aargh ... I have to use TOR at this WiFi hotspot which is causing me some consternation ... I finally downloaded the file, about 5.43 MB or so. I'll try it with DReaM later so I thank you.
Old 04-12-2018, 00:19   #287
Work is progressing on DReaM's ability to decode xHE-AAC broadcasts. Really, it's way past time for broadcasters to adopt it instead of ancient AAC+
https://sourceforge.net/p/drm/discus...?limit=25#b45e
Old 18-02-2019, 16:55   #288
About a month ago, Julian posted an updated version of DReaM for the Windows 64 operating system. Ensure you download the HELPER FILES, i.e. the QT Multimedia libraries for SVN 1077 of DReaM as well. * Evidently, DReaM is moving away from Pulse Audio to QT Multimedia for audio. Hopefully, Julian can release an updated version of DReaM soon for enabling xHE-AAC for transmission as well as reception. Currently, the FDK library which includes MPEG-D capability, i.e. USAC or xHE-AAC, is version 2.
* Evidently, the HELPER FILES do NOT include the binaries, just the project files for compilation with Visual Studio which most listeners probably won't have available. I guess you could try Microsoft's Visual Studio 2017 community version to compile these project files. So, most of us will probably have to wait until Julian addresses these current problems.
Old 10-03-2019, 11:40   #289
The forthcoming DReaM will be significantly different internally from older versions which is good. Personally, I've had nothing but problems with ALSA's polling of devices on previous versions of DReaM. Users of older versions will be forced to update or buy dedicated xHE-AAC SW radios. Although potentially more expensive for some, these changes to DReaM's code should be better for everyone. Getting rid of FAAD is just one example.
Old 11-03-2019, 13:26   #290
DRM-OM
Could you please be more specific?
Expensive?
Having to pay for something?
DRM-OM is offline   Reply With Quote
Old 11-03-2019, 13:40   #291
DRM-OM
just tried the snapshot (win7/64bit) - I only get:
greetings ...
some german language info pages on DRM
Old 11-03-2019, 15:57   #292
Expensive?
No, you shouldn't have to pay for anything as long as you upgrade to the latest version of DReaM. The current development versions of DReaM are naturally incomplete while Julian works on them so it'll be awhile until users have a workable and reliable version of DReaM. I'll let the readers of this forum know when ready if someone else doesn't do it first.
Old 11-03-2019, 20:28   #293
DRM-OM
thanks for the info.
btw: I just tried the Ubuntu version and also got stuck:
Code:
$ sudo apt install qt5-qmake qt5-default libsndfile1-dev libfftw3-dev libhamlib-dev libz-dev libpulse-dev libpcap8-dev libpulse-dev libpcap-dev libopus-dev libspeexdsp-dev libqt5svg5-dev libfdk-aac-dev [sudo] Password for user: Packet lists are read... Done The dependency tree is created. Status information is read in.... Ready Note: "zlib1g-dev" is selected instead of "libz-dev". E: Package libpcap8-dev cannot be found.
greetings ...
Old 12-03-2019, 01:00   #294
Yep,
IIRC, I received a similar error when attempting to compile a recent development version. In your case, the pcap library is apparently missing.
Old 11-04-2019, 01:37   #295
More snapshots released on March 31st, but are probably not worth the effort experimenting according to Julian. He is still working on stabilizing the 2018 branch of DReaM before continuing work on the 2019 branch which will eventually decode xHE-AAC broadcasts. The 2018 branch uses FDK to decode HE-AAC+, but not xHE-AAC.
Old 15-04-2019, 18:20   #296
Julian released a new Windows dream.exe executable this weekend under the SNAPSHOT folder at Soureforge. It's probably without any GUI, just command-line only.
I tested this latest release from Julian and it seems to decode HE-AAC+ alright with a previously recorded file. I receive a lot of "other error 4005" errors in the terminal, but it does decode. I didn't have any strong live streams to produce audio from this latest release of DReaM, but I did see some output in the terminal regarding changes in sampling rates.
So, well done, Julian as FDK does seem to decode HE-AAC+ streams.
Old 25-04-2019, 00:21   #297
Julian,
I'm posting this log here as I'm fairly certain it will find its way to you on Sourceforge:
See the attachment for the error compiling r1273 which seems to be fixed in version 2.2. However, with my older version of GNU/Linux, I had to add QMAKE_CXXFLAGS += -std=c++0x to dream.pro.
Now, I've manged to compile v2.2, but I receive following error when attempting to run dream:
barrett: _init back from rig_register
stoprec
~CSoundInPulse
stoprec
~CSoundPulse
initplay 48000 38400 0
CSoundOutPulse::Init_HW()
pulseaudio output device 'alsa_output.pci-0000_00_14.2.analog-stereo.equalizer', init done
CSoundCardSelMenu::OnSoundOutDeviceChanged alsa_output.pci-0000_00_14.2.analog-stereo.equalizer
output device changed in trx alsa_output.pci-0000_00_14.2.analog-stereo.equalizer
Working thread started
initrec 48000 1280 1
Assertion 's' failed at pulse/stream.c:2660, function pa_stream_set_buffer_attr(). Aborting.
Aborted
BTW, Julian has released v2.2 of DReaM with FDK decoding of AAC+ only at this time, I believe. Both GUI and non-GUI (console) versions of this release are available for Windows.... Try it out!
Old 25-04-2019, 01:07   #298
How did you get around the missing QT platform error? I've tried copying various likely-looking .dll's around, but to no avail.
Old 25-04-2019, 01:45   #299
Chris,
Look under the 2.2 folder in the files section on sourceforge.net. If you have, I apologize as I haven't tested 2.2 yet on Windows. I've been testing on GNU/Linux. If someone else hasn't solved this problem on Windows by morning, I'll look into the issue. Julian should have included those missing DLLs for the QT5 platform somewhere in the files section, probably the full version.
Here's the link for the version 2.2 directory:
https://sourceforge.net/projects/drm/files/dream/2.2/
Old 25-04-2019, 03:34   #300
I'm using the dream-2.2-win32-vs2017-full.zip download on Windoze 10 64-bit.
I've tried several of the newer snapshots and they all have the same problem. I'm guessing it doesn't show up if you have the QT Development kit installed on the same PC, but I long ago gave up trying to compile Dream on Windows. Just too hard compared to Linux.
