Old 17-08-2019, 11:04   #31
Aug_16
I received the transmission, between two interfering AM carriers. I got some German speaking audio as well as the label and I run a log. See both attachments.
Old 17-08-2019, 14:36   #32
Pretty much the same result here, both gave a label but the 9 MHz broadcast was a lot stronger and gave me a bit of audio.
Maybe conditions will be a bit better for the September tests.
Modified NRD-525G with
Radiokit DRM Decoder Board,
SDRplay RSP-1A,
Airspy HF+ Discovery
SDR Console v3
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
https://www.ndblist.info
Old 01-09-2019, 18:37   #33
DRM Hdn
DRM Hdn's Avatar
11990 kHz 1700-1800 UTC
No chance for a reception here in germany!
i saw a very little signal via websdr from hungary...without a chance for decoding. thats only sad!
Old 01-09-2019, 19:21   #34
DRM Hdn
DRM Hdn's Avatar
9540 kHz 1800-1900 UTC
Same disaster on this frequency
Old 01-09-2019, 19:40   #35
Sept_01 RTI 9540 kHz
The transmission started earlier and still is running.... Bad results.
(Transmission ended at 19:00.)
Old 01-09-2019, 20:08   #36
No signal in Northeast France of 11990 Khz.
Old 01-09-2019, 20:14   #37
Bad signal of 9540 Khz is very difficult to receive RTI just 3 secondly audio :
https://nsa40.casimages.com/img/2019...2017579464.jpg
Old 15-09-2019, 20:10   #38
Sept_15 - RTI on 9540 kHz
Good signal. A result for 14 mins @ 99.5% CDA / 21.4dB max SNR.
Old 16-09-2019, 00:58   #39
@John: I was asleep (and I forgot about it too). Could you tell me if the audio was as bad and distorted as it used to be?
Old 16-09-2019, 10:06   #40
@Terje, yes audio distorted due to over-modulation.
Old 16-09-2019, 12:42   #41
Aha, they never learn... time to take a trip to Taiwan ... !!
