Old 14-06-2006, 00:34   #16
June 13
Could be better.
Loop positioning is quite critical, see report.
Old 14-06-2006, 17:34   #17
MOBILE RECEPTION
Driving from 48712 Gescher at 65km distance to TX to Ibbenbueren via A31, A30.
This log shows the limitations of DRM on lower frequencies.
There was only a light thunderstorm and some electrostatic rain reducing the CDA to inacceptable 60%. 5kW simply is not enough, see my next report on 1296kHz.
Old 15-06-2006, 07:13   #18
Good results until 2330, but then conditions got worse for 1 hour, not sure what caused the problem, later again quite good.
Old 15-06-2006, 08:26   #19
Good parts and very bad parts last night.
Old 18-06-2006, 22:18   #20
An hour ending in the usual WDR 2 Klassik nonsense:
An interview programme with a jazz musician and classical music in between instead of the discussed jazz.
Multiple impulses already in the early evening despite the short distance.
Old 19-06-2006, 17:44   #21
Good results last night using the Sony radio/ ferrite antenna.
Old 19-06-2006, 21:45   #22
MOBILE RECEPTION
Driving from 48712 Gescher to near 49565 Bramsche via A31, A30, A1.
Signal fading north of A30/A1 crossing. Maybe it's some directivity of my antenna on the left back of the car. I somehow get better results with signals coming from the front or the right side of the car than with signals from the back or the left.
Tuned frequency to 1296 kHz near Bramsche for comparison.
Old 20-06-2006, 06:18   #23
Quite good again last night.
Old 21-06-2006, 21:08   #24
Considering that this log was done by DRM Software Radio, I would call this a nearly perfect result.
Old 21-06-2006, 21:30   #25
MOBILE RECEPTION
Driving from Gescher to Bad Eilsen via A31, A30, A2 with a big dropout at a fuel station:
Old 21-06-2006, 21:50   #26
DRM-OM
Not very impressive
less than 50% Audio
greetings ...
Old 21-06-2006, 23:27   #27
PaulT
PaulT's Avatar
no audio here, snr not greater than 8, channel clear at the time.
paul t
PaulT is offline   Reply With Quote
Old 22-06-2006, 00:42   #28
PaulT
PaulT's Avatar
later some audio, very good quality-when received
Paul T
1593 wdr.txt
Old 22-06-2006, 08:32   #29
June 21
Audio drops out a bit too often. I guess it might work better at lower bitrate.
Old 22-06-2006, 16:37   #30
Good results and great audio quality on this transmission.
