Go Back   DRM Software Radio Forums > DRM Software Radio - User Forums > Reception Results - Archive
Old 17-12-2006, 22:59   #1
jbriggs
James Briggs
jbriggs's Avatar
9730 kHz RTL test
I would be grateful for comments on the following planned for tomorrow, Monday December 18th for 1 day only:
9730 kHz from Austria 1100-1230 UTC.
50 kW DRM
Antenna HR 4/3/0.6
295 degrees (Benelux)
Any comments on audio quality field-strength etc much appreciated. Thanks, James
jbriggs is offline
Old 18-12-2006, 13:00   #2
Hi James,
started quite good, only a weak signal after the first 35 minutes for the rest of the transmission, no problems with mode A, audio quality was OK considering the bitrate.
simone is offline
Old 18-12-2006, 13:01   #3
... also no problems with the MP40 at the beginning.
simone is offline
Old 18-12-2006, 14:10   #4
LX1RE
Reception BelRTL Morphy Richards
Reception with Morphy Richards in my home in Luxembourg, Average low fieldstrength, some dropouts, worse after 12:10 UTC with SNR's below 9dB. Rather bad sound quality, audio input level seems to be not correct.
73's
Eugene LX1RE
LX1RE is offline
Old 18-12-2006, 15:25   #5
Hi James,
same results like Simone. After the first 30 min, no reception was possible again. See graph with fieldstrength. Sound quality was not the best.
carknue is offline
Old 18-12-2006, 20:08   #6
Here is a typical example what the audio spectrum looked like and a recording
from music and speech.
simone is offline
