Old 01-07-2015, 06:20   #826
30 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC. There were no obvious breaks in transmission and the SNR was very constant. There was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 2-. Local K-index 2.
Planetary A-index: 6. Solar flux: 99. SWPC Sunspot number: 36.
Sunset 20:24 UTC.
N.B. The time on the plot is wrong by +1 hour.
Old 01-07-2015, 16:28   #827
Mikey
Actually there were about 2 or 3. However unlike previous occasions this was only for a few seconds at a time rather than minutes. Was also checking the spectrum on sdr# so saw the carrier disappear.
Old 02-07-2015, 05:54   #828
Hi Mike, thanks for the correction, you have an advantage over me in that I can't see the spectrum of the signal.
Old 02-07-2015, 06:05   #829
1 Jul 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC. There were a couple of short breaks in the transmission, and the decoded audio was only 99% rather than the usual 100%.
18:00-21:00 UTC Planetary K-index 0+. Local K-index 1.
Planetary A-index: 6. Solar flux: 110. SWPC Sunspot number: 41.
Sunset 20:24 UTC.
Old 03-07-2015, 06:28   #830
2 Jul 2015 : Voice of Nigeria 15120 kHz
The transmission was late, and was on air from 18:19-19:30 UTC. There were a couple of breaks in the transmission. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 0+. Local K-index 0.
Planetary A-index: 5. Solar flux: 114. SWPC Sunspot number: 49.
Sunset 20:23 UTC.
Old 04-07-2015, 06:07   #831
3 Jul 2015 : Voice of Nigeria 15120 kHz
No signal was received tonight, so I assume it was off the air.
Old 05-07-2015, 06:54   #832
4 Jul 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC. When on air there was 100% decoded audio. After the first 5 minutes the SNR drop by 10 dB.
18:00-21:00 UTC Planetary K-index 5+. Local K-index x.
Planetary A-index: 3. Solar flux: 115. SWPC Sunspot number: 91.
Sunset 20:22 UTC.
Old 06-07-2015, 18:32   #833
5 Jul 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC. Again there was an almost a 10 dB drop in SNR towards the beginning, which occured after a break in transmission. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 3. Local K-index 3.
Planetary A-index: 19. Solar flux: 122. SWPC Sunspot number: 111.
Sunset 20:22 UTC.
Old 07-07-2015, 06:25   #834
6 Jul 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC. There were a few more drop outs than normal, so only 99% decoded audio.
18:00-21:00 UTC Planetary K-index 2+. Local K-index 3.
Planetary A-index: 25. Solar flux: 133. SWPC Sunspot number: 131.
Sunset 20:21 UTC.
Old 08-07-2015, 05:52   #835
7 Jul 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:03-19:30 UTC. Again there were a few more drop outs than normal, so only 99% decoded audio.
18:00-21:00 UTC Planetary K-index 1-. Local K-index 2.
Planetary A-index: 10. Solar flux: 133. SWPC Sunspot number: 109.
Radio blackouts reaching the R1 level.
Sunset 20:21 UTC.
Old 09-07-2015, 06:16   #836
8 Jul 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC. There was a 7 minutes break in transmission about an hour into the broadcast. When on air there was 99% decoded audio.
18:00-21:00 UTC Planetary K-index 2. Local K-index 2.
Planetary A-index: 5. Solar flux: 128. SWPC Sunspot number: 118.
Sunset 20:20 UTC.
Old 09-07-2015, 21:34   #837
9 Jul 2015 : Voice of Nigeria 15120 kHz
Old 11-07-2015, 08:56   #838
10 Jul 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC. There were two short breaks in transmission, when on air there was 99% decoded audio.
Planetary A-index: 6. Solar flux: 128. SWPC Sunspot number: 120.
Sunset 20:19 UTC.
Old 11-07-2015, 15:52   #839
Hi Neil,
Our logs look much the same with the breaks and flaws around the same time.
Old 13-07-2015, 05:43   #840
Hi Terje, good to see your log, there seemed to be a change to the programmes on the 10 Jul 2015, as instead of a programme called '60 Minutes' there was an hour of local pop music.
