Old 14-06-2015, 06:15   #796
13 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC and had 100% decoded audio.
18:00-21:00 UTC Planetary K-index 3-. Local K-index 3.
Planetary A-index: 7. Solar flux: 137. SWPC Sunspot number: 96.
Sunset 20:21 UTC.
Hi Mike, strange how you had fluctuations on the received frames, as our locations and antennas are very similar!
Old 14-06-2015, 07:26   #797
Mikey
Yes very strange. The results on 9760 yesterday being the most extreme example but there have been others. The only thing I can think of that might explain it is the fact that I live on the edge of an industrial estate and near to the great western mainline. So lots of potential sources of electro magnetic noise. Also because I live in a shared house all my antennas are located indoors. That said when monitoring 9760 yesterday there was no sign of any interference on the spectrum.
Old 15-06-2015, 06:51   #798
14 Jun 2015 : Voice of Nigeria 15120 kHz
Planetary A-index: 10. Solar flux: 133. SWPC Sunspot number: 97.
Sunset 20:21 UTC.
Old 15-06-2015, 19:48   #799
AIR's DRM broke down so I caught the very end of Nigeria instead. Perfect decoding in this short log
Old 15-06-2015, 20:25   #800
Tony
Horrible audio quality
The DRM audio quality of VON is appalling. I was under the impression that this was a temporary thing part of the start-up but it keeps on going.
My advice to VON is to stop these DRM transmissions if you can not correct this problem.
I wonder is anybody at VON listening to these DRM broadcasts? I doubt it.
So VON management get your DRM act together or stop DRM transmissions completely.
With this quality it is a wast of time and money and you annoy listeners like myself.
Tony
Tony is offline   Reply With Quote
Old 16-06-2015, 06:02   #801
15 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC with a 5 minute break just before 19:00, when on air there was 100% decoded audio.
Planetary A-index: 20. Solar flux: 133. SWPC Sunspot number: 117.
Sunset 20:22 UTC.
Old 16-06-2015, 06:19   #802
Poor Audio
Hi Tony, good to hear from you. I must confess the quality of the transmission is certainly not up to BBC standards! Some of the problem is the quality of the original audio is poor. I am sure you are right that nobody at VON is actually listening, as I am sure you will be aware that they were transmitting for many months without any programming at all!
I wonder where your location is Tony?
Old 16-06-2015, 07:29   #803
Poor audio
Hi Tony and all,
The audio and the DRM configuration has been (almost) the same since day one.
Old 16-06-2015, 09:30   #804
Originally Posted by Digger
Hi Tony and all,
It is not just VON (and AIR) that has a problem with the audio for DRM transmissions. In 2004 I was in contact with Jan Peter Werkman of Radio Netherlands. But at least they responded: "Anyway we are aware of the problem and we'll see what we can do in the near future to improve the audio levels."
Old 17-06-2015, 06:08   #805
16 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC with two 5 minute breaks in tramission. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 2. Local K-index 2.
Planetary A-index: 14. Solar flux: 134. SWPC Sunspot number: 107.
Sunset 21:22 UTC.
Old 18-06-2015, 05:51   #806
17 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC with a couple of small breaks, and one break of 5 minutes. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 0+. Local K-index 1.
Planetary A-index: 10. Solar flux: 133. SWPC Sunspot number: 87.
Sunset 20:23 UTC.
Old 18-06-2015, 19:45   #807
June_18
A result for 73 mins including a TX break down, 98.84% CDA.
Old 19-06-2015, 06:36   #808
18 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC with one short break in transmission and there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 1+. Local K-index 2.
Planetary A-index: 14. Solar flux: 568 (very high). SWPC Sunspot number: 94.
Sunset 20:23 UTC.
Old 20-06-2015, 07:13   #809
19 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC with one short break in transmission. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 0+. Local K-index 0.
Planetary A-index: 6. Solar flux: 136. SWPC Sunspot number: 82.
Solar radiation storms reaching the S1 level.
Radio blackouts reaching the R1 level.
Sunset 20:23 UTC.
Old 20-06-2015, 19:44   #810
Mikey
Another almost perfect result
