Old 02-06-2015, 19:44   #781
June_02
~98% CDA, not bad.
Old 03-06-2015, 06:47   #782
2 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:27 UTC which is the new time of this transmission. There was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 0+. Local K-index 1.
Planetary A-index: 8. Solar flux: 102. SWPC Sunspot number: 38.
Sunset 20:11 UTC.
Old 03-06-2015, 07:41   #783
Perfect reception last night (2nd June). I logged for one hour and then "left" for AIR.
Old 03-06-2015, 22:51   #784
3 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:00 UTC (which was half an hour shorter than they had previously announced) and had 100% decoded audio.
18:00-21:00 UTC Planetary K-index 1. Local K-index 2.
Planetary A-index: 3. Solar flux: 107. SWPC Sunspot number: 39.
Sunset 20:12 UTC.
Old 05-06-2015, 12:58   #785
4 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC and had 100% decoded audio.
Planetary A-index: 4. Solar flux: 121. SWPC Sunspot number: 55.
Sunset 20:13 UTC.
Old 06-06-2015, 08:59   #786
5 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC, but there were a number of breaks during this period. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 0-. Local K-index 1.
Planetary A-index: 3. Solar flux: 125. SWPC Sunspot number: 80.
Sunset 20:14 UTC.
Old 07-06-2015, 11:19   #787
6 Jun 2015 : Voice of Nigeria 15120 kHz
No signal was received tonight, so I assume it was off the air.
Old 08-06-2015, 06:29   #788
7 Jun 2015 : Voice of Nigeria 15120 kHz
During the schedule of 18:00-19:30 UTC, there was a one hour period of no reception. I assume this was due to transmission problems. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 3-. Local K-index 3.
Planetary A-index: 5. Solar flux: 140. SWPC Sunspot number: 129.
Sunset 20:16 UTC.
Old 09-06-2015, 06:28   #789
8 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission did not start until 18:09 UTC and had 100% decoded audio.
18:00-21:00 UTC Planetary K-index 4-. Local K-index 3.
Planetary A-index: 7. Solar flux: 136. SWPC Sunspot number: 136.
Sunset 20:17 UTC.
Old 10-06-2015, 06:35   #790
9 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC with one break off two minutes towards the beginning. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 3. Local K-index 3.
Planetary A-index: 33. Solar flux: 131. SWPC Sunspot number: 122.
Sunset 20:18 UTC.
Old 11-06-2015, 05:59   #791
10 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC and had 99+% decoded audio.
Planetary A-index: 13. Solar flux: 135. SWPC Sunspot number: 110.
Sunset 20:19 UTC.
Old 12-06-2015, 06:20   #792
11 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC. There was a 10 minute break in transmission at 18:03 which caused a problem with the Newstar generated plot. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 1+. Local K-index 2.
Planetary A-index: 12. Solar flux: 137. SWPC Sunspot number: 105.
Sunset 20:19 UTC.
Old 12-06-2015, 19:51   #793
June_12
A result for 51 mins at 97% CDA.
Old 13-06-2015, 08:52   #794
12 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC with only one small break and there was 99% decoded audio.
18:00-21:00 UTC Planetary K-index 2-. Local K-index 2.
Planetary A-index: 9. Solar flux: 140. SWPC Sunspot number: 101.
Sunset 20:20 UTC.
Old 13-06-2015, 22:07   #795
Mikey
Not bad but a few fluctuations here
