Old 25-01-2009, 11:18   #1
Voice of Russia from Kaliningrad on 6105 and 7325
the Voice of Russia is on air now on this new frequency in German.
Strange label but strong signal.
Edit: Just added the log. A strong AM station began broadcasting at 1300 UTC on the same frequency and killed the DRM signal.
Old 25-01-2009, 13:41   #2
Looks like it was a transmission from Kaliningrad: http://kaliningrad.rtrn.ru/news.asp?view=10450
Kai Ludwig reports in A-DX that there might be a transmission at 2000 and 2300 UTC on 6105.
Old 25-01-2009, 18:59   #3
Indeed, on the air now on 6105. Here's the log. Strong QRM and fading, so 8,45 % CDA only.
Old 27-01-2009, 13:55   #4
Jan.27
Short log from 7325. small part of audio !!!!
Old 31-01-2009, 12:16   #5
dadalbinder
7325 kHz VOR
Hallo,
hervorragendes Signal mit groer Konstanz.
Die TX-Parameter in DRMCalc scheinen nicht zu stimmen.
Wolfgang Hartmann
Old 09-02-2009, 10:01   #6
Thanks for adding this transmission to the official DRM schedule.
PERFECT reception right now, 28 dB SNR. Bitrate could increased a bit, 14 kbps sounds quite "special"... audio level is a bit high.
Just heard this new frequency in the program -> offical?!
Old 14-02-2009, 12:10   #7
Good results today. Audio level is still a bit too high.
Old 15-02-2009, 14:18   #8
Good results today, 99% CDA for 135 minutes.
Old 22-02-2009, 12:07   #9
Good results again but bad audio-quality as usual. But anyway, it was worth listening to! Voice of Russia had a small joke-session today... haha.
Old 02-03-2009, 19:53   #10
Thumbs down DRM car radio
Gescher-B525-A43-A1-B58-A2-A33-Paderborn
Reception quite good in the car, but the audio quality is very poor!
The sound is compressed, clipped, distorted, simply not suitable for DRM.
And even more this constant terrible background noise in the story about Novgorod (they think it is music) was a real torture.
Old 17-03-2009, 12:08   #11
Good rf signal, SNR Maximum [dB]: 40.7
Still regular resyncs on my side using VAC.
Audio level still much too high, sound is compressed and clipped!
Old 25-03-2009, 11:20   #12
DRM car radio
Nottuln-B525-Gescher
Bad audio quality also out of the car hifi speakers, bitrate too low.
Strong mumbling noise behind voices and music sounds very distorted.
Old 31-10-2009, 10:58   #13
First log on the Russian broadcast: Quite good - Nice to see them in the air on this frequency, one of the good ones here. Audio quality is not perfect at 14.06 kbps, but I think it's okay.
Later I tuned to KBS so the second part of the log will be added later. Unfortunatly, this log will start with CPU overload and a nice drop-out while uploading the first log right now.
Edit: Just added the second part - perfect!
Old 31-10-2009, 13:58   #14
Strange result:
SNR was changing between exceptionally high and low. During the low periods the snr spectrum behaved like in a thunderstorm, but I could see nothing like that in the panadapter.
SNR Maximum [dB]: 42.5
If the result is right that was a new record for my Flex-5000A.
I'll check tomorrow if I can repeat that.
The audio was in low quality at very high level.
Old 01-11-2009, 14:41   #15
Todays reception verifies yesterdays results, excellent snr values from Bolshakovo:
