Old 13-10-2010, 00:44   #1186
Logger received no signal.
Old 13-10-2010, 21:10   #1187
stef
stef's Avatar
nothing decoded today i think day have tx problems
stef is offline   Reply With Quote
Old 14-10-2010, 20:49   #1188
stef
stef's Avatar
same as yesterday,a big hole in the ionosfeer
Old 14-10-2010, 20:52   #1189
Nothing stuck in my log so far this evening.
Old 14-10-2010, 21:09   #1190
Here also some periods with deep fading and no audio but good in between.
Some sound problems, zipped mp3 sample attached, sounds like a buffer problem.
Old 15-10-2010, 21:25   #1191
Today also one fading period and one local resync, but in all still good reception.
Old 15-10-2010, 21:56   #1192
Wow Fritz,
All I got was an "Ayer's Rock" - from Chile, not from Down Yonder... hi.
Old 16-10-2010, 21:15   #1193
Originally Posted by Digger
All I got was an "Ayer's Rock".
Hi Terje,
I think reception of CVC in Scandinavia is almost impossible.
Why not try RNZI, should be better than in Switzerland!
Tonight extreme propagation conditions:
Within minutes the signal faded away to nothing, DReaM crashed, and later within minutes the signal came back much stronger than before with SNR max. 27.3 dB!
Old 16-10-2010, 21:32   #1194
Good results in the last 20 minutes tonight.
Old 17-10-2010, 21:03   #1195
stef
stef's Avatar
Nearly nothing until 19u28 than it went super,snr off 24db
Old 17-10-2010, 21:03   #1196
Tonight a very weak start, then a longer TX break, and finally a very good and strong comeback.
Listening to CVC gives very different/ new results every evening!
Old 17-10-2010, 22:00   #1197
Yes, I believe the season is over here for 17 MHz, and this will be my last try from Stockholm. The signal disappeared around 1900 UTC and never recovered.
@ Fritz: 7.440 MHz and NZ is still weak. Check that thread.
Old 18-10-2010, 21:16   #1198
@Terje
Here the 17 MHz season also seems to be over. Audio disappeared around 18:40 UTC and the signal stayed in the noise to the end. I missed that DReaM crashed in between, but that made no difference.
Old 19-10-2010, 09:32   #1199
@ Fritz,
Usually 17 MHz from Chile seems to fade out around the change to Winter schedule at my Swiss QTH. There was no trace of anything here in Stockholm last night.
Old 19-10-2010, 22:06   #1200
stef
stef's Avatar
Bad decoding
