Old 21-08-2019, 03:39   #1
SPECIAL DRM TRANSMISSIONS DURING HFCC MEETING (B19) IN ARGENTINA 26-29 AUGUST 2019
Special DRM shortwave transmissions are being planned for the special meeting of HFCC to be held in Buenos Aires, Argentina, 26-29 August. They will be broadcast by Encompass Digital Media Services 16.00-17.00 UTC on 21630 kHz from Ascension Island on a bearing of 245 degrees. On each of the 4 days the content will be supplied by a different broadcaster:
Monday BBC World Service English
Tuesday KBS (Korean) in Spanish
Wednesday NHK (Japan) in Spanish
Thursday TWR (TransWorldRadio) in Spanish
Vatican Radio-Vatican News will also carry a special broadcast in DRM during the HFCC meeting from Monday 26-Thursday 29 August at 18:30 -19:00 UTC on 17535 kHz from Santa Maria di Galeria beaming to 230. Vatican Radio will broadcast music with text in English and Spanish.
https://www.drm.org/special-drm-tran...-26-29-august/
Francisco Braccini
DRM: Smart Radio for All!
Old 26-08-2019, 16:33   #2
Aug_26
A faint trace of the signal but I got the label.
Old 26-08-2019, 17:02   #3
Aug_26
...After ~16:35 the signal turned better and I run a log.
Old 26-08-2019, 18:42   #4
DRM Hdn
DRM Hdn's Avatar
Aug_26
...not a trace of an signal here
Old 26-08-2019, 20:16   #5
26 AGO 19
No signal from the BBC.
Excellent signal from Vatican Radio News: https://youtu.be/xHlCRw64Hdw
Francisco Braccini
Old 27-08-2019, 16:25   #6
DRM Hdn
DRM Hdn's Avatar
27 AGO 19
no chance for a reception here, but i saw a good signal via sdr.hu from switzerland from the bbc.
Old 27-08-2019, 17:03   #7
Aug_27 BBC 21630kHz.
Different propagation conditions this evening, some fragments of audio from BBC.
Old 27-08-2019, 19:18   #8
Aug_27 17535kHz Vatican Radio.
I received the transmission. Very good music audio (~12kHz BW) + voice announcements, for the conference, in English and Spanish. A mode change noticed. I run a log. See the plots, including the label and the DRM mode.
Old 28-08-2019, 11:51   #9
The TX list was updated! I will check tonight but probably nothing strays into Japan...
Old 28-08-2019, 16:19   #10
To moment 16H00 UTC of 21630 Khz medium reception from BBC WS SNR from 10 to 21 DB.
Old 28-08-2019, 17:00   #11
Aug_28 21630kHz BBC WS.
No luck this evening...
Old 29-08-2019, 17:24   #12
Aug_29 21630kHz BBC WS.
I received the transmission this evening. I heard music from the "Preludio of La Traviata by G. Verdi" + Spanish speaking voice.
Old 29-08-2019, 19:30   #13
Reception from yesterday 28.8.19, is curious datum is 12 January :
https://nsa40.casimages.com/img/2019...3451623668.jpg
Old 29-08-2019, 19:35   #14
This Day 29.8.19 then SNR was 4 to 15 db many audio cut very bad reception.
Old 29-08-2019, 19:42   #15
Reception from Radio Vaticana was many beter of 17535 Khz :
https://nsa40.casimages.com/img/2019...4721221531.jpg
