Old 04-03-2020, 13:53   #586
Testing my MSI.SDR, a chinese 50 Euro 12-Bit SDRplay RSP-1 clone.
Works quite well with SDRuno software/driver and VB-Cable.
Old 05-03-2020, 11:12   #587
Perfect reception also with HDSDR Software:
Old 08-03-2020, 12:52   #588
Solid reception, good audio:
Old 09-03-2020, 12:02   #589
Unattended log, DReaM crashed in between.
Old 09-03-2020, 12:56   #590
March_09
A result for 157mins @ 99.9% CDA / 22.4dB max SNR.
At ~13:00 an AM carrier appeared affecting SNR and decoding. I assume that it is the same QRM from the same origin which noticed last year.
Old 10-03-2020, 12:47   #591
March_10
An unattended log for 210 mins @ 99% CDA / 23.4dB max SNR.
Old 11-03-2020, 12:31   #592
MARCEL
Hallo Fritz,
Hier nur mit 21,5 db maximum aber gute audio, leider war dass fast dass Ende 13H27 :
https://nsa40.casimages.com/img/2020...4537190559.jpg
DRM:
Mixer Platine MF9 Mhz with Dream
Antenna:
Mantova Turbo 5/8 wave for 27 mhz
Long Wire 80 meter
MARCEL is offline   Reply With Quote
Old 12-03-2020, 12:49   #593
March_12
An unattended log for 153 mins @ 100% CDA / 21.7dB max SNR.
Old 13-03-2020, 13:04   #594
March_13
A result for 102 mins @ 99.8% CDA / 26.1dB max SNR.
The effect of QRM on the SNR figure can easily be seen in the plots.
Old 23-03-2020, 12:39   #595
March_23
A result for 158 mins @ 99.8% CDA / 24dB max SNR.
"Staying home" I spent some time building a forgotten mini Whip, designed by pa0nhc. I tested it today without taking any special measures to avoid of picking-up noise. The mini Whip was hang inside the attic below the roof. The output signal was about 20dB less compared to that of the ALA330S loop antenna which I mainly use in the same place.
Old 24-03-2020, 12:31   #596
March_24
A result for 185 mins until the signal dropped and decoding stopped, 23dB max SNR.
Old 25-03-2020, 12:58   #597
March_25
A result for 168mins @ 100% CDA / 23.8dB max SNR.
Old 26-03-2020, 11:58   #598
March_26
Transmission late start and early end. 99.98% CDA / 22dB max SNR.
Old 28-03-2020, 12:31   #599
March_28
A result for 52mins @ 99.9% CDA / 21.5dB max SNR, in the presence of co-channel QRM after 13:00 (1st plot).
Old 29-03-2020, 14:28   #600
March_29
A result for 154mins @ 92.7% CDA / 24dB max SNR, in the presence of strong co-channel QRM (CNR + VOA).
