Old 23-05-2013, 18:33   #1
PP5AZF-Ataliba
KTWR 15.570 khz
KTWR is planning a DRM test to Japan for May 24th and 25th. The transmission will be in Japanese on 15570 at 1230-1300 UT. KTWR will be beaming at a heading of 335 degrees, running a 75 kW, allowing Japanese listeners in Russia and the EU to tune in as well.
http://www.drm.org/?p=2126
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
www.youtube.com/atalibazf
Old 23-05-2013, 20:01   #2
And like Chris wrote on the 10th May regarding 15570 kHz (quote):
"We should have good side lobes into Southeast Asia and possibly India. The main beam should be quite strong in Europe. The main back lobe will be toward NZ. Thanks for your help.
Mike"
Old 24-05-2013, 12:40   #3
Thumbs down AM QRM from China
China on the same frequency kills all DRM. 550 or 560 are free but 15570 is unfortunately impossible. Otherwise, 17.46 kbps would be OK for good reception in Scandinavia.
Old 24-05-2013, 13:04   #4
Yes is one other station in Asiatique language of this frequencie and I have Fading, little audio from 12H45 to 12H47 then only screen display SNR 6 to 11,7 maxi, is very dammage I no receive MOT Picture Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Old 24-05-2013, 13:13   #5
Mitsuru Ito
in JAPAN
It was strongest signal.
I must use attenuator.
DE JA2QDX M.Ito
PS;I have put VON's log file.
Mitsuru Ito is offline   Reply With Quote
Old 24-05-2013, 13:22   #6
DRM-Belarus
DRM-Belarus's Avatar
SNR was 9...15 dB in Minsk. Not enough to decode MSC QAM-64. But audio sometimes appeared. Unfortunately my DR111 didn`t log data once again :-( I was listening Radio Mayak yesterday for 3 hours. The same result, no logs. Occasional logging by DR111 is a little annoying.
DRM-Belarus is offline   Reply With Quote
Old 24-05-2013, 13:56   #7
OT
One foolproof method of logging with the DR111 is to insert a SD card, then power-up. Tune to the desired DRM frequency and then try to save any audio by pressing and holding the <clock> key. If you get a silly message that the SD capacity is low, physically unplug the DR111's power source and then replug it. Repeat the aforementioned process of trying to save any audio by pressing and holding the <clock> key. If the recording proceeds ok, then simply stop the recording if desired by pressing and holding the <clock> key again which will save the brief recording. You know now for sure the logging will be saved to the SD card if you were able to briefly record to it. Yes, this procedure is a pain, but it's foolproof. CDNSE needs to address this issue among a few others in a firmware update...
Old 24-05-2013, 14:14   #8
DRM-Belarus
Thanks for the guidance. I`ll try your method :-)
My method is to press "DRM" button in order to hear previously recorded audio on SD card (4th position). If "no playback file" is on the screen, then SD card is not available and I replug the power source. But as you see this approach doesn`t guarantee logging.
Old 24-05-2013, 14:24   #9
At least, I THINK it's a foolproof method, but I've been wrong in other matters. Tread carefully and test. The key to reliable recording and logging with the DR111 seems to be removing and then reconnecting the power from the AC outlet to the unit after inserting a SD card. Use whatever method is easiest and most reliable.
Old 24-05-2013, 15:32   #10
Like I mentioned in a previous message, China on the same frequency killed all DRM here. 15.550 MHz or 15.560 MHz were free from signals but 15570 is unfortunately impossible. Otherwise, 17.46 kbps would be OK for good reception in Scandinavia. Due to the QRM it was not possible to download any pictures from the slide show. I believe the Chinese TX had a short failure (?) around 1245 UTC, and then the only burst of audio got through in DRM.
Regarding logs with DR111: Tune to a DRM signal, let the DR111 begin playing (or show a Label), then insert the SD Card. At the end of the log FIRST switch the DR111 to St.-By, THEN remove the SD Card!
Old 24-05-2013, 18:22   #11
May_24
As others mentioned the QRM too, here attached is a proof of that from my area.
Old 24-05-2013, 21:26   #12
Very difficult to receive KTWR, I have screen copie und little audio dammage not MOT Picture :
http://nsa34.casimages.com/img/2013/...2611302744.jpg
Voir le Fichier : DRM_TWR-GUAM_24513_15570_12H30.mp3
Old 25-05-2013, 13:22   #13
Another chance, another try, another disappointment... The configuration of KTWR was favourable with 17.46 kbps, but the ionospheric conditions with Aurora:9, A:20 and K:4 were not in favour of DX:ing. Then, one minute into the transmission China started in AM on the same frequency. That transmitter seemed to go off the air just before 1245, but soon after another Chinese fired up 5 kHz down and splattered into KTWR's DRM spectrum ruining all odds of any decoded audio. All this effectively eliminated any chance of seeing any of the slides.
Old 25-05-2013, 13:40   #14
I have receive with very difficulty, SNR from 0 to 13,8 db but fading, 12H38 audio many cut, 12H47 signal to Up audio better to 12H48 signal SNR 13,4 12h50 to S6 no more audio :
http://nsa34.casimages.com/img/2013/...4057349113.jpg
http://nsa34.casimages.com/img/2013/...4136953805.jpg
Old 25-05-2013, 13:57   #15
Mitsuru Ito
Angry in JAPAN
it was not strong today.
signal was 10dB over S9 by S meter of IC-R75
But yesterday signal was 20dB over S9
And there were strong interferencs.
DE JA2QDX M.Ito
